These are the big 3 IMHO. REX-121 in a Farid Custom, CPM S-125-V in Fantonis, and CPM S-110-V Custom Blade in a Buck 110.View attachment 1937526View attachment 1937527View attachment 1937528
Yeah I love it, it's a great steel for sure and I definitely didn't mean to impugn its honor by denying it supersteel status. I just understand 'supersteel' to only apply to alloys which fundamentally break the traditional steel performance envelope in some way. Like M390 family showing such good wear resistance and corrosion resistance with an appetite for hardness, it's fundamentally different from the traditional understanding of stainless vs carbon steels where stainless generally means buttery in a way.One of the best balanced steels out there however when you take all factors into consideration. It’s tough, holds an edge plenty good, and isn’t ridiculous to sharpen. Oh and stainless too
Lol see post #121, they are hereI won't get tired of SuperSteels until the Super Duper ones show up!
@000Robert What is that chain link or whatever it is made of? That's pretty crazy.
Busse just came out with the Free Rein: 16" blade of 3V beauty!
The other thing you can do, and it is a long term plan, is gradually make the angle more acute each time you sharpen. I'm not sure how practical that is with a fixed angle system though, depending on what you have.I'm super stoked right now. I've been experimenting with using and sharpening different steels. My latest sharpening job today was on a Pena X-Series Apache, so Reate heat treated M390. I was kind of dreading it but this time I stuck with the factory edge angle which was in between 21 and 22 degrees per side. I just gave her a whole new edge from 140 grit up to 600 grit on diamonds in about 45 minutes max conservatively. Maybe I've just been focusing on reprofiling all my knives to the optimal angle lately too much and should just go the easy route and match the angle. It sure makes for a whole lot less time spent.
That's a fantastic idea. Each sharpening go back one or two degrees. I think that's what I'll do on this Pena. It's quite a bit too obtuse of an edge for my liking at 22 degrees, but next time I'll get her down to 20, then I suppose the next time I'll go to my sweet spot of 17. I like that. The whole reason I like to go below 20 degrees, besides it slicing like an animal, is so that I can use my Sharpmaker in between big sharpenings at 40 degrees inclusive. I can maintain my edge at 20 degrees on the sharpmaker for a long time before having to reprofile again and it's sooo fast and easy with the sharpmaker if your geometries right. Good callThe other thing you can do, and it is a long term plan, is gradually make the angle more acute each time you sharpen. I'm not sure how practical that is with a fixed angle system though, depending on what you have.
Consider it minor reprofiling each time you sharpen. It will still be a little bit more time consuming but not as bad as a full reprofile in one go.
Just an idea anyway.
Yea everyone that I've seen that has a Wicked Edge seems to really like it. I'd love to try one, it looks like a really cool design and built very well. It's cool seeing how each of these companies figured out a way of doing the same thing, each one very different in the way that it gets done. Maybe someday I'll find someone local that will let me check their's out and try it out of curiosity, however I decided on the KME and am going to stick to it for the simple fact that I poured a decent amount of money into it with the thought that I'll be able to sharpen my knives for the rest of my life with it. I may need to get another set of stones or two in that amount of time, but I saw it as a long term investment.I have been using a Wicked Edge sharpener for quite a few years and upgraded to this model a few years ago. It gives me the ability to accurately and easily sharpen any knife. I think the higher end steels are easier to sharpen than very low end steels. I sharpen my knives which are anything from Beta Titanium to H1, M390, S90V, etc. I don't find that much difference in use that I can notice as well as ease of sharpening, other than non-steels and H1. The only time I have a longer sharpening job is when I change angle from the original / previous grind. I usually carry a couple of knives normally; one for general use and one for unforseen emergency which does not get used. I use knives hard at work as a marine technicial on a submarine and as a diver. I cut a variety of ropes, nets, firehoses, gaskets, wires, etc. Because I am in and around the ocean constantly, I use an H1 Spyderco a lot and have a L100C model in que to replace it at some point. I also have been using a Mission MPK12 in Beta Titanium which continues to surprise me with it's cutting ability. I did re-angle the blade and put a much finer finish than the original which really made a big difference in cutting ability. I have reall been using this knife hard, for several weeks now, and it is holding up well.
But you have the option of spending 5 minutes a week on the "super steel" don't really have the option the other wayI'd much rather have a blade steel that only requires 5 minutes a week rather than 45 minutes a month.
