Huh. Seems I stumbled on something, here...
Now, it occurs to me that the tendency for Torx screws to strip, or be generally hard to work with, might be a way for manufacturers to encourage return business. If your pivot strips out, you can send it back to them to have the pivot replaced, for a nominal fee, of course.
But I'm a cynical person, so I'm probably wrong....
I also followed the good people here and purchased a Wiha set, which works great. Now that we are discussing this topic, I wonder what exactly is the cause of stripping? Is it because the torx bit does not fit the screw head perfectly? Or is it because the torx bit is too soft, i.e., softer than the screw material?
What is it about the Wiha set that makes it less likely to stip torx screws? Are they like softer and thus less likely to strip softer screws.
The fit. They have a much more precise fit (as long as the screws you're using them on are quality and in spec) than any other brand I've tried.
edit: and, no, they aren't particularly soft (compared to the screws), but they are tempered to be very tough and flexible, meaning they're not as easy to twist or round off as cheaper brands.
