Titanium Axe... what say you?
Those are exactly the specs and behaviors of cast straight grade 5, with a couple extra HRC points attributable to a less pure alloy. For blade use, less pure is better than more pure. Grade 23, which is 6al4v ELI (extra-low interstitial, super pure) is the worst of the 6al4v iterations for a blade precisely because it's so pure. The miniscule impurities in basic alpha-beta alloys like grade 5 imbues a micro-alloying effect and improves everything, including hardness and work-hardenability.
Whenever people ask me about titanium blades, I'm gonna say a lot of weird and true stuff nobody cares about, and none of this really even matters.
What matters is:
-Is it what it's said to be, a cast titanium alloy hatchet? Yes.
-Does it do what it's supposed to do? Yes.
-Are people happy with it? Yes
Seems like a good deal to me, I bet it's awesome and your input will make the design even better, and I insist that in general ti alloys are simply misunderstood and underrated for something like an axe. I straight-up want one, but don't have the extra cash right now because I make titanium stuff by hand which will ruin one's life. I'm dumb and should have had axe heads cast a long time ago. I did look into having stuff cast by an aerospace parts company that uses a hardenable ti alloy, but the cost was astronomical. Same for 3D printing. And for long thin stuff like swords and machetes, forging is the only process that yields the results I want.
Someday in like the year 2060 I'll be a homeless old man with heavy metal poisoning, sitting on a street corner, and I'll say, "I used to make legendary titanium alloy swords, you know!" And some punk on a hoverboard will be like, "Ok boomer, whatever. Everyone knows titanium doesn't have enough rockwells to hold an edge." Then he'll power up the hoverboard and speed off, kicking dust in my face, and I'll probably stroke out right then and there because that's what the Rockwell hardness thing does to my blood pressure.
Thanks for the intel--very good to know. Naturally there's only so much that gets communicated to me as an external designer rather than being involved in direct communication with the manufacturer, and little details like that are helpful when it comes to making optimization tweaks and adjustments!
For our viewing audience here, one thing I want to stress (no pun intended) is the work-hardening effect for something like this hatchet. Work-hardening doesn't even capture it, so I used to call it "seasoning." Ti alloys, especially alpha-beta alloys, are sado-masochistic and love to get slapped around impacted. The more it gets used, the better it will get. This effect isn't subtle, you will notice it by the third sharpening when it seems like it never needs a fourth. It will "awaken" as it's used, and literally get stronger.
My heat treatment techniques reduce this effect by a lot, by drastically changing the crystalline matrix, but it really only works on a Beta or near-Beta alloy, by converting a large part of the matrix from Beta into Alpha Prime, or even Alpha Double Prime, which is also called "titanium martensite." This is a very internally-stressed form.
This isn't a thing in titanium industrial use. Normally the properties of each alloy are altered through alloying alone, with or without the intent of solution treating and aging, which is to increase strength, refine grain, reduce stress, equalize, etc, not to harden. Whatever Rockwell hardness results is simply a side effect and has little to no bearing on expected mechanical properties. In fact an HRC test on titanium can be like 5 points above or below the average number on a single sample, and is not considered a useful metric in titanium engineering.
The hatchet's performance will not be determined by a Rockwell test number, but that number will go up with use. For blades there is still a correlation.
Edit to add, for use as a blade titanium will naturally be "harder," but it isn't like a 'What Rockwell you run that at?' kind of thing. I just use the term "harden" because that's the word typically used to describe the effect. Alpha Prime is significantly harder than an Alpha-Beta matrix as a matter of course, but the hardness number isn't the goal. The goal is to put the titanium into a form where is can NOT gall, take a set, smoosh, roll, etc. If it is impacted beyond its yield strength, it will instead chip or break a little piece off of the edge, but this takes something crazy like swinging and hitting a rock. Even in this form, it isn't very abrasion-resistant but is incredibly stable and strong, even for a fine thin edge, and is flexible but quite stiff.
I ended up talking to the Wrango guy for a while on the phone, discussing titanium vis-a-vis what the internet thinks, tool designs, elimination of harmonic resonances, etc. Cool guy. And he sent me some hatchets to thrash!
As a natural spazz, the one with the spike is kinda scary so I will mainly be using the one with the flat hammer on the end, which was slipped onto the longer of the two handles.
The sheaths are made of leather. The blades are quite sharp, like chop-your-fingers-off sharp. The geometry looks good for titanium alloy use.
I'll be using the crap out of it, and will report back!
Looking forward to your reports......
But, I like the looks of Yours better!
awesome. lookin forward to your take on them.
Beat this blade up pretty good burning some weathered 2x6 boards from old raised garden beds. I used the hatchet to whack the boards into thinner sections.
It's so light weight that it can be used with a flick o' the wrist, but also a serious chop. Unsurprisingly to me, it's almost like using a hatchet-shaped big chopper knife on a stick, rather than a normal hatchet. I would solidly classify this as a tomahawk in use, form, and function. Titanium "hatchets" can be optimized by thinking of them as such, and shaping the edge and bevel more like that of a bigass chopper knife.
First I gave one of my pressure-treated blade testing logs a few normal-power whacks. I do the same for machetes and swords. Even thin machetes get chopped repeatedly with full power into something like this during testing:
Not too bad.
Then I got to splittin' and burnin' the 4 and 8-foot 2x6s. It was easiest to just lay the board down and whack it, causing it to split. A few hard whacks was able to split most of the 8 footers. Often I just buried the blade and twisted it like a froe, splitting the board:
Hit this large deck screw, and buggered the edge up a bit, which is fine. It will just be even better after it's sharpened:
It was a fun and useful tool for working a nice campfire. I'd like to have this with me anytime while camping.
I think it's a good tomahawk/hatchet, that could be improved with a few little changes to take better advantage of the titanium alloy's peculiarities.
Thanks for the review. Are those changes you mention on the manufacturing side or changes that the end user can do?
Mine is still unused since the only work I did over the weekend was chainsaw work.
Just a bit of finessing the shape that would make it more effective. Some the user could do, but mostly a change to the casting.
Performance goes way up once thinned.
Of course a thinner one should be used with more skill and not so brutally, like any blade.
Indeed.
Mass times acceleration equals force. A lighter head needs to be traveling much faster (impossibly fast) to deliver the force to the wood. It may have a use but not as an axe.
It’s the same reason titanium hammers are worthless.
Niche product that someone will buy, just not me.
