Morgoth412,
For clarification purposes lets limit the discussion to folding knife handles only.
In your arguments you have never discussed how manufacturing different materials can justify using more expensive materials.
Some materials like carbon fiber, G10 and micarta have manufacturing limitations. For example, these materials sometimes have problems when cut with a waterjet. The layers can delaminate. The materials also cannot be fine blanked or cut by EDM. Resolving these problems can be achieved by using a different materials like titanium or stainless steel. When using wire EDM, a 2" stack of scales can be cut at the same time with a tolerance of .0002!
Carbon fiber, G10 and micarta will not hold up or wear quickly when used directly against blade steel for a lockback or liner lock. If the liner lock wear problems could be resolved, carbon fiber, G10 and micarta would have to be manufactured pre-bent. You cannot put the bend in them after they are built in sheet form.
Another manufacturing problem with carbon fiber, G10 and micarta is the creation and disposal of waste. The dust created from machining these materials is nasty and requires proper disposal. Titanium chips are recycled and part of the cost of materials recouped.
In an earlier post you wrote that other materials have better grip. Titanium can be machined to have any level you desire, equal or surpassing the other materials you listed. Have you held the new Kershaw Bump? The ridges provide tremendous grip to keep the knife from sliding forward or backward.
Think of materials from a manufacturers point of view. If the knife design has a high enough price point, titanium is easy to manufacture and sell.
The biggest problems with using stainless steel over titanium is weight and customer demand.
Some earlier point made by other people need to be clarified.
* Titanium weighs about 60% of steel.
* Titanium is stronger than steel by weight.
* Two identical sized parts, one steel and one titanium. The steel part is much stronger.
* Titanium is cool.
