- Feb 7, 2014
I finally got around to installing the TKC handles on my BK4. My initial impression was favorable; but I had some concerns about the roughness, since I tend not to wear gloves as often as I should.
I took the 4 outside to play today - thinning a stump that I left taller than I should have. (It's on a slope, and I was working comfortably; figuring I can always trim it with the chainsaw, or just chop it shorter.) This was a tree I took down a few months ago.
There was no batoning involved, and minimal chopping.
If you look closely, you can see the problem in the above image...but here's a more direct shot.
Anybody else experienced this?
Obviously, it wouldn't have happened with the stock handles - barring a hardware failure - because the handles are bolted through holes drilled in the tang. The TKC handles don't utillize those holes (as has been pointed out in other threads).
Oh - for the record - given the nature of the attachment, I did have them pretty darn tight....or so I thought.
Edited to add: The problem was that my kit lacked the metal dowels that would have stabilized the scales. The response from TKC was quick and professional; but I had already made my own replacements
