- Feb 7, 2014
If you bought the scales new then you should have received two small ziplock bags with them. The scales come with two sets of screws, one set for the regular size Beckers and one set for the thicker ones like the BK-2 and BK-3. Included in the BK-2 ziplock are the steel dowel pins to use with the scales for either size.
The Dowel pins go into the two original holes from the stock hardware in the handle of the knife and then the ends go into the holes in the scales them self. That will keep the scales from sliding around on the tang.
Here are some pics showing the parts you should have received.
Hope that helps. And if you can't find the original pins, it would be a simple fix to make a set of your own.
-Dex
I did purchase them new/directly from TKC. I did receive both plastic bags....but I don't recall the dowels being there (I was expecting something like that, though). Maybe they were in the bag I didn't use, and I missed them because I didn't open it. I'll check when I get back
