- Dec 27, 2004
The difference is the mobility of the abrasive particles. The burr is a result of the abrasive catching onto the steel and pushing some out of whack as it scrapes material away. Grinding action is basically scraping material away (aside from CbN if properly aligned is more of a tooling action). When it scrapes, it forms a wake at the lead edge and the sides of the abrasive, whether it is leading or trailing - though trailing will make a more pronounced burr faster. This wake is what forms the burr.
As the abrasive becomes more and more loose, it catches and digs less. Some of the abrasives will slide between the workpiece and the stone, some will tumble. The burr that forms as the steel is pushed past its ability to resist, becomes smaller - with a hard fixed abrasive the abrasive wins out and the wake is going to be determined by the properties of the steel and how much pressure the abrasive has behind it. With a more mobile abrasive the furrow might generate enough resistance the abrasive shifts before the burr reaches the same size - now the wake is influenced in some part by the properties of the binder the abrasive sits in, or the texture of the surface the abrasive is resting on.
When the abrasives are more free to roll, slide and tumble the conditions that lead to burring are greatly reduced. As you get closer to lapping you might have no burr form. I also noticed on some stones intended for different industrial sharpening applications, the binder was so soft the edge would barely form a burr even with a fair amount of force on a trailing pass. Many softer waterstones fall into this category and almost have to be used with a trailing pass to get good results. Loose grit on a hardwood knifeboard is the same principle - you can grind with a scrub or a leading pass, but to clean up the edge it had to be finished with a trailing pass.
Same steel, same stone, first pic with slurry, second is no slurry. You can see in the slurry image almost no trace of the track marks stopping in mid grind, the average depth is less....
Thanks again for the reply.
Obviously a difference in your pictures (I combined to make comparison a bit easier)...
... but couldn't it just be that a stone with slurry creates a finer finish than a stone with no slurry? So, finer finish = less burr... no different than just sharpening on a finer stone.
I spent a bit of time this a.m. on a King 1K waterstone with slurry and no slurry... honestly couldn't tell much difference, other than a bit more 'misty' finish with slurry.
Anyway, thanks again... something I'll play around with a bit more, and see what happens.
