- Mar 10, 2011
Jake - Dremel makes a grinding bit that has a small cup in the end of it for things just like this situation. I have a few of them in different sizes. You only use the cup for grinding (not the side of the bit) and it is a fine/medium grit bit. It will take that spring pin down just fine. I got a GEC Powderhorn with the same problem. I spun the bit around the pin and it lowered the pin nicely.
You don't have to have a dremel tool/motor to use it. A regual drill will do. The brass pin may be soft enough that you can spin/twirl it with your fingers.
Remember! Whatever you decide, "slow and easy" does it. It doesn't take much pin (material) removal to get it down so it's just right.
Excellent post and suggestion, thanks for that info about those bits!
I have a bunch of Bucks and have come across the occasional high pin...I used to mask off the handle and go at them with tiny hobby files, then a sanding stick ( Popsicle stick with wet/dry paper glued to )
I believe this pin to be steel, but it won't be hardened, those bits Ed described could also be turned by hand in a pin vise...although time consuming, it could be done.
Now I need to find some of those bits
