John Phillips
Platinum Member
- Jan 13, 2020
Sorry to hear Gary. Glad you’re ok.
Yeah my wife has been wearing one for quite a while and says it definitely helps.Glad to hear everyone is on the mend.
I wiped out on my bicycle a few years ago and really jammed my wrist, sleeping with a wrist brace made a huge difference. According to my doctor, you bend your wrist in strange ways when you sleep.
Thanks guys, while it's still healing, I was doing some 'repairs' to our small shed. The doors to the front have rotted sections across the top and along the bottom. My neighbor just got a big stack of cedar boards about 5 1/2" wide and varied in length and he said I was free to use what I needed from that stack of wood. So, I took the top section first, cut across to get rid of the rotten area and put in two pieces of the cedar. Now removing things using a claw hammer I found that my right wrist, the 'bad' one REALLY did not like the impact that vibrated back down the hammer's handle!!! and while I can do a lot with my left hand, hammering is not one of themso after attempting to use the hammer my wrist needed to recoup a bit more, so ice and wrap were the two as well as some motrin.
The second day I realized that the lower parts of the two doors I would not be able to do while they were hanging, so, I took each one off and used a circular saw to trim off the bad sections and even up the border panels and proceeded to insert the cedar planks. All told it doesn't look half bad...maybe half good lol but it is better.
Then I thought, hmm an awning would be handy, to keep the rain from the doors a bit, so I worked on that today, just a narrow board across the two doors screwed into a strip of pressure treated board with a 25 degree angle and the boards were at the 5" wide, had to make lap joints to get a section wide enough to span the 55" across, and then used some silicon sealant to cover the top sections to prevent water from getting things soaked. One last bit will be to paint it, fortunately my wife loves painting, while I tolerate it, I'm just not interested in it and the end results of anything I paint proves that point very clearly
G2
