- Nov 18, 2009
Ah yes.. the old 2x42. I still have mine and I still use it.
Thanks for the comments Javand. I bought my disk grinder because I'm trying to get more efficient at getting true surfaces... flat surfaces. Which I realize that I could be doing with my mill whenever I get to acquiring the proper tooling. I also want to use it to get flat, true bevels on long blades like swords.. and perhaps some swooping plunges on knives. I was also thinking it would make nicer machine finishes for a smooth transition to hand rubbing.
Jim... Thanks a lot. That is what I was envisioning when I bought this. Do you use it to reshape your plunge after grinding on the belt??? Are you using sheet paper or buying pre-cut ceramics? By the way... does anybody know if it's worth buying the ceramics? Or go the route of bulk, cheap, change often?
I use regular paper and cut to fit disc's. I actually cut my paper oversize by about 1/8". This overhang will clean up the plunge cuts very nicely. Really nice haveing extra discs so I dont have to tear off paper that is not fully used up. Many times I have went up a grit and then find out I didnt get all the scratches out from previous grit. Then I would have to peel off the new paper to put another lower grit. With the magnetic palte system I can just switch plates without wasteing paper. It saves a lot of time and money on sand paper.
Jim
