- Jul 23, 2015
You're not seeing the ones that have since been corrected once called out.![]()
I stand corrected! I guess I just like to look for how I can give the benefit of doubt, but sometimes that benefit evaporates...
I didn't read their explanations. They have m390 and 20cv listed in different categories. They clearly don't know what they are talking about.What do you all think of this list knife depot sent me
https://blog.knife-depot.com/knife-myths-premium-steels-are-always-better/
Man, you're going to go on a wild goose chase if you're just looking for concrete affirmations about the best steel, your asking a question as silly as what's the best vehicle, look outside, vans, trucks, cars different kinds for different things and no one size fits all.What do you all think of this list knife depot sent me
Which brand of S30V? I had a 531 Benchmade and found it hideous...![]()
CTS-XHP is my favorite steel, followed by CPM-S35VN. Truthfully, the only PM steel I've disliked is S30V.
it chipped like mad and was a pita to sharpen. (bevel angle and thickness behind the edge not cool)
Meanwhile a fellow knife nerd was saying how wonderful Spyderco S30V worked for him...in a Para 3.
I bought a Lil Native in S30V and started using the hell out of it. First off, it can go 2 or 3 weeks
before it won't shave hair. Second of all it takes like 2 or 3 minutes on the Sharpmaker to
get very sharp. The sharpening time alone makes it a winner...and it has chipped once in use.
I cut a lot of cardboard and one box caused a tiny chip...which took 3 minutes to fix!
I find that Spyderco S30V makes for a great EDC steel. It does not seem to chip much and
it holds a working edge long enough to make me happy. And it is easy to sharpen.
Obviously, the blade profiles in my example have to have a giant impact. I find myself
loving the full flat Spyderco blades over everything else.All of my Spydies have symmetric
edges too which are also at an angle that works great with the Sharpmaker.
Para 2s I own in S30V have also been stellar and easy to sharpen.
I own a Para 2 in M390 but I have no idea what sharpening it is like. It still does not
need it! I use it very little to be fair.
I have heavily used 154CM as well and sharpened it many times. S30V is better to me.
I have yet to get a blade in CTS-XHP but from what I have heard, it is excellent.
I have blades in D2, M4, and K390. But I never actually use them...I just carry
them occasionally. (Benchmade Infidel, Spyderco Advocate, Spyderco Police 4 G10)
You talk to muchMan, you're going to go on a wild goose chase if you're just looking for concrete affirmations about the best steel, your asking a question as silly as what's the best vehicle, look outside, vans, trucks, cars different kinds for different things and no one size fits all.
The problem with your question is that the knives performance is the sum of all components not just the steel, so if we give you answers you'll just get tunnel vision.
Another problem is your skill level in use and sharpening will also change what will perform better.
Just use these generalities, more stuff in the steel makes it more expensive and cut longer but perhaps more prone to damage with misuse and may be difficult to get sharp if one lacks sharpening knowledge, ability and harder abrasives. The advantages being you can sharpen when you want to not because you have to. It's not that it stays laser sharp forever but that it doesn't blunt with cutting as easy and can physically cut longer.
Less stuff in the steel may help it fit into non cutting roles better where the biggest concerns are breaking rather than cutting longer. Will have a lower learning curve to use and maintain but simply doesn't cut as long.
There are always caveats and exceptions and I could write a book about the specifics but this will get you started.
I'd recommend getting into sharpening if you want more answers and narrowing down your preferences and uses with experience will help out find what's best for YOU.
I like my steels on the extreme side, that doesn't work for everyone though.
Gimme Rex121 at 70rc,
15v at 67rc
Oh I'm just trying to be nice and go further in detail, when I was new, no one really went out of their way to explain much or "why" except for a very small handful of folks. Just paying it forward.You talk to muchTry this way..................With nearly every steel, you’ll have to trade off one thing for another.
Well said, and full of wisdom, but I wish you had saved this for your 30,000 post! Holy cow!1) Again, top for what? Based on what application? Based on what properties? AUS8 is one of my favorites because it keeps a great edge well, is easy to sharpen, and isnt expensive. It has never broken despite what you have convinced yourself.
2) Your "you get what you pay for" theory doesn't apply. There are a ton of great inexpensive knives and a ton of terrible expensive knives.
3) Learn to sharpen.
4) Read more HERE. You have gotten bad information and there is a lot of it out there.
5) Again, while you are pushing the reset button, get a Mora, get a SAK, get a VG10 Delica, get a CV Case, and get a Sharpmaker and USE THEM.
Everyone here was at the point you are. The solution is not to throw wads of cash at high priced supersteels. That is just being a marketing department's dream.
The solution is to learn about metal properties through use and find what charactetistics suit you.
THEN go chase steels with the junkies!
I never buy cheap knifes... KNIVES!!!
