Top ten comfy knives.
I just did some family photo's of my top ten most comfortable knives. So here they are (order of preference goes from top left to bottom right).
In case you're wondering, yes, that's eight Spyderco's and two Kershaw's in the picture, about 1/3 my collection of folders (mostly Spyderco's and Kershaw's).
To describe what makes a knife comfortable can be pretty difficult. It's not just size or length. I've noticed that there are specific shapes that work well in my hand, and some very subtle choices that can make or break a design.
Before I get to the dissection, honorable mention should go to the Caly 3. It is the perfect little knife, but can't perform as primary EDC (just incase it didn't sink in, the Caly 3 is perfect).
Handle design, in my thinking, primarily falls into two categories. First is the more common, "ball" handle philosophy, where your hand engulfs the handle and the butt end rests on the pad, or "heel" of your hand. Second is the "stick" philosophy, where the handle runs across the entire length of your palm, and the butt end of the knife does not touch your hand.
Of course, which knives fit into which category is partially determined by how big your hands are, but you can usually still see which knives were intended to be held one way or the other.
The top two knives on my list, the Civilian and the Military, encompass the "stick" philosophy almost flawlessly. If you clench your fist, you'll notice that the pads of your hand extend past your pinky finger. If the knife handle ends at the same point as your pinkey finger you've still got a little less than an inch of pad left un-used. These knives extend the handle past your last finger, and contact your palm across it's entire width.
Next, take your fingers and bend them at a forty-five degree angle to the back of your hand. You'll notice two distinct folds in the palm of your hand. With your hand open, they form the most distinguishable lines. The upper one running from the pinkey finger to the middle finger, the second running just beneath the first and across nearly the entire width of your hand. The spine of the handle (at least with the Military) curves gently and follows the second line fairly closely, also following the natural curve of your hand while holding it. The handle is also wide and thick enough to fill the distance between your fingers and the palm of your hand, taking into account the length of each finger.
The best example I've come across of the "ball" philosophy is number three on my favorites list. The Mini-Manix. I don't know if it was intentional or if Eric Glesser just happened to get it right, but the handle on that knife just melts when I hold it. Similar to the "stick" philosophy, you still want the handle to follow that line in your hand (which shows the separation between pads of the hand). This time the critical difference is that it's not the handle spine resting one the heel of your palm, it's the butt end. The length of the handle ends with your pinky finger. The Captain (middle bottom row in the picture) takes advantage of this best, the spine of the handle rests on the pad at the base of your thumb. Where that pad ends, the handle makes a sharp turn to fit with the pad at the heel of your hand. The Captain pulls it off beautifully. the other knife that trys to do this is the Kershaw Offset. Unfortunately, it doesn't do so well. It's too long to rest the butt of the handle on the heel of your hand (should have been a "stick" design), but because the design keeps the butt of the handle pushed into your palm, it also keeps the handle away from the ring and pinky fingers. If there had been another "lump" where there is now a "dip" the knife would have been fantastic. Sadly this is not the case.
Which brings me back to the Mini-Manix.
Not only is the handle nice and thick, it bulbs and dips at just the right places. First, the handle is a good width for the index and middle fingers to grip. It thickens not only to account for finger length, but "bulbs" behind the ring finger, filling the swell of the palm (the dip in the middle). By filling that space, the handle is pressed up to the fingers without need of extra width at the end of the handle (see Military), this is also aided by the long thumb ramp. if the thumb ramp is too far back, the thumb pushes the handle forward, pivoting it on the index finger, and pushing the butt of the handle into the palm, and away from the fingers (the Offset accomplishes this pivoting off your middle finger with that huge ridge, even though it has a long thumb ramp). If the thumb is allowed to extend, then the handle can be pulled into the grip of the fingers, and there coddle them like babies.
That sums up the basics of what I've figured out so far. If anyone else has specific likes/dislikes about handle design, feel free to speak up.
Good choices but I think you missed one of the most comfy knife ever made. For the grand total of $26, you can get yourself a real workhouurse. Try a Buck 110...you won't be sorry.
I will second the Spyderco Manix (both reg and mini) and a ZT 0300. These knives fit perfectly in the hand, at least mine anyway. Great drip and ergos. I also like the Strider SnG and PT as well as the Sebenza Classic handles.
Forgot to add my Benchmade 720S and several Kershaw's I've owned or handled.
I totally agree with you on the Superhawk, mini manix, the millie, and the chinook. I would have to add the full size manix, blade-tech Pro-Hunter, and the Kershaw JYD 2
Thats odd, a lot of spydercos I have felt did not seem to be comfy to me at all. The endura, which I carry at work, is a good knife but not comfortable.
Agreed on the Endura - it's adequate, but not what I would consider comfortable. The Mini-Manix and Military (haven't handled many of the Spydies pictured) are VERY comfortable. I like the ergos on the Chinook, though the grip options felt too limited, but for hammer-fist "stick" grips, it's great.
I'm rather surprised the Ener-G II isn't there. It's "tear-drop" handle melts into the hand.
Of all those pictured,I'd agree with the ZT0200,The Chinook & The D'Allara DP as the most comfortable handles I've ever experienced.Also like to throw in Kershaw's JYDII & the Speed Bump to the mix ;):thumbup:
As others have mentioned, Kershaw's JYD II has excellent ergonomics ... very comfortable even during long sessions of heavy cutting.
I'd add the Benchmade 800 full-size series knives, as well as the 710, as being comfortable to use. Then, too, the Microtech Amphibian is comfortable to use.
I'll second the 110 as one of the most comfortable knives I have ever held. :thumbup:
The JYDII is very confortable as well.
Interesting. All of them are folders, so they logically give up some ergonomics because you have to combine a handle and "sheath" into the same space, so to speak. (yeah, yeah, I make large fixed blades in case ya didn't know..lol) I guess comfort is a relative thing.;) With that said, my all time favorite "modern" folder was the original plain edge Benchmade AFCK although I got to check out Kevin Wilkins' replacement handle for the Griptilian in Gembloux and that was pretty nice..
Well, I've always wanted a custom shoppe 110, this may be just the excuse I need...
No UKPK??
While not exactly the same knife, the Caly 3 is close enough. I guess I'll have to say it one more time, the Caly 3 is the perfect little folder (being so similar you could apply that statement to the UKPK if you want). I guess you could say the Caly 3 is so good that it surpasses top ten lists, and is simply an anomaly of the knife world. It shouldn't be possible, but it is.
Actually, I guess the title of the thread is a little misleading. It should probably read "top ten comfy folders". I have both the Spyderco Forester and the Rock Salt, both of them knock everything else out of the park (the Rock Salt in particular). Only problem is I have a hard time EDCing them. The Rock Salt does pretty well, as it's only one ounce heavier than the Offset, but I haven't found a belt carry system that keeps it out of the way enough for daily carry (I dream of having that knife implanted in my leg someday). I make my own sheaths and have tried several carry methods, the latest comes close to being EDCable but it's just not quite there yet.
Not that I've given up, I'll keep trying new things and refining ideas until something that can be carried long term is produced, it just takes a long time. Living in a country where Fixed blade carry is still legal, it would be a shame not to take advantage of that fact.
I guess you like the Spydercos... but have you tried much else? Or should this thread read "Top Ten Comfy Spyderco Folder Knives"?
He's got some kershaw's in there mind you. ;)
I agree with the Military/D'Allara. I didn't come of age fast enough to get in on the (Mini)Manix. The D'Allara has got to be the most comfortable folder I've ever handled besides the Military, and they come withing mere inches of each other at that finish line. The millie is big and comfy, the D'Allara is wide and very grippy. Also love the Ball-Lock on it. :thumbup:
Nice line-up there :), although I'm surprised you don't have a Native of some sort up there. Most describe that as the most comfortable Spydie.
Guilty as charged for liking Spyderco. They have this tendency of offering high quality at a good price point, and thier knives consistently surprise me.
I keep a good eye on Benchmade and Kershaw, my favorite Benchmade is the 14255 (well, in hindsight I wish I had got the 14250), it has a lot of design characteristics I appreciate. Benchmade knives generally don't interest me quite so much as they seem to stick to designs that are more visually pleasing than they are ergonomic. Though the 610 and 630 are right up my alley, right now I'm waiting in hopes of an M-4 variant.
Most other companies don't offer good enough steel for my taste (I am a steel snob at heart).
I have always thought my emerson commander had the best/most comfy handle, its just sad I won't be buying any more knives from them.
