- Nov 17, 2005
Hello everybody,
I am brand new here and this is my first post to this site.
I’m going to stick to the basic question, with a little background.
My experience is military and emergency medical along with some side by side time with law enforcement and SPECWAR.
Survival gear is just that, GEAR. It is tools we use to save time or make other tools with. If you can get by without something, a fork vs. chopsticks carved on the trail, that’s fine, but maybe someone else really really feels they NEED a fork. Let ‘em. As long as they pack it and I don’t have to haul it in or out, go fer it! Our main assets are our mind and everything in our immediate environment. If we can turn it to our use, then it may take the place of something we didn’t have to ruck in. If we can’t get a hold of it or don’t know yet how to use it to replace other gear items, then it may as well be on the surface of the moon. I look at basic gear as, MOSTLY, time and labor saving devices. They can also be life saving devices.
For a one month hop I would be looking for very serious multi-function gear.
The “Ten Item” limit and backpack size package is admittedly a little amorphous, but I’ll try to focus on a standard 3000 cu. in. size pack (Old ALICE size pack). The ten items will be given small package status. If a kit can be enclosed in a small space, roughly an Altoid tin or waterproof match safe then I will classify it as a single item. My real exception to that rule is the First Aid Kit. I’m a medic, indulge me.
Assuming proper clothing for the environment and time of year, which can be a whole list in and of itself…
Following the Rule of THREE’s I will break it out by group.
Water
1. Katadyn Pocket filter (13,000 gal capacity)
2. Nalgene 48 oz. collapsible bladder canteen, free standing
Heat / Shelter
3. 120 Hour Nu-Wick candle 14 oz.
4. Thermolite Emergency Bivy Sack 36 x 84" 7 oz.
5. Ultralite Sil-Nylon Tarp 8 x 10' 13 oz.
6. 550 Paracord - 200' + (14 oz.)
7. MSR Cook Pot, .75 L (or larger) (Full of lots of the stuff on this list)
Food Procurement and General Utility
8. Cold Steel Trailmaster Bowie Knife (Carbon V steel used with BSA ferro rod fire starter) in Kydex sheath and two accessory pouches attached to sheath (Multi-tool, vial of Polar Pure Crystals, Fresnel Magnifying lens, Bic Butane Lighter and snare wire 100 ft.
and
Match Safe Kit
Fishing / Suture / Floss / Sewing / Fire starting kit
12 needles - 3 each light & heavy, curved & straight.
6 split shot, 3 swivels, 200 ft. of Spyderwire 30# (12# dia.) test line
36 fish hooks & 12 dry flies threaded onto safety pins
Boy Scout Ferro spark rod (fire starter) and 3 tinder tabs)
9. Leatherman Wave Multi-tool (carried in accessory pouch on Trailmaster sheath.)
10. First aid kit:
Polar Pure crystals, Boric acid powder, Betadine, sugar, salt, Gatorade powder, Kerlix 4" Gauze fluff roll x 2-3, 3" Ace wrap, Band-aids x 12-36, Duct tape x 30 ft. (repair or 1st Aid), Polysporin ointment, TP, sunblock, Chapstik, Germicidal soap, Garlic/insect repellant, toothbrush/ paste, hot glue stick, Ibuprofen (30 tabs), Benadryl (30 tabs), Immodium AD (20 tabs), antacid (20 tabs), Lotrimin AF or Lamasil ointment tube, hemostats x 3, scissors x 2 [EMT Shears, fine point Iris scissors], Maxi-pads x 10(as wound dressing, tied in place or duct taped), Q-Tips (vital for eye care, in Altoids tin), tube of Vaseline PJ [skin care & fire starting aid w/ pure cotton cloth, Maxi-pads or Q-Tips], another Bic Butane Lighter.
I don’t need a compass, last I checked, the sun and North Star haven’t started changing their relative positions in the sky. If I have to live for a month before rescue, I guess I am supposed to be out of range of people and or not supposed to know where I am, and a compass without a map doesn’t do you a lot of good anyway. If you have to hike out, follow your natural lines of drift and you’ll find some sort of civilization sooner or later. Just hope they aren’t cannibals.
A soft spot to sleep as well as extra insulation will be gleaned from the local area and stuffed under and into sleeping gear and / or clothing.
Ordinarily I put it into a 10 + 10 list, including firearms, always, even if it is only a .22 pistol. I will play rabbit and avoid big critters and bad guys for this scenario.
Certainly you can do with less than this and countless of our ancestors have, and they flourished for centuries. But if I don’t know where I am to go or what I may encounter when I get there and I realize that I may not know enough about the local weather conditions, flora or fauna to easily adapt to my environment, I need to stack the odds in my favor. You may not need to do so, but then again, you may be better looking than me too. I can only address my own situation and wish you luck in your own.
Conquer yourself first, all else will follow.
KJM
Water
Heat / Shelter
and
Match Safe Kit
10. First aid kit:
KJM
