- Sep 29, 2008
Saying there is no benefit to screws being harder, just don’t torque hard so you don’t strip them sounds alot like saying a car doesn’t need to be good at protecting passengers in a crash, just don’t crash it.
That still doesn’t explain why harder screws would not be better. In no way am I saying that the screws should be made so hard as to be brittle.
What if the screws came in at 30hrcx would it not be better for them to be abit harder? Well whatever the screws are coming in at now, I think it could be better if they were closer to that 55hrc.
If one cannot tighten his screw down fully for fear of stripping it, how does one prevent it from backing out? Putting even purple loctite would requite more torque to undo the screw than was ever put on them just by tightening them down to a degree where they were fully seated.
I still don’t see how a hardened screw is useless. If it will allow a greater degree of user error then that doesn’t seem useless to me.
I still think the biggest issue is the use of t6 screws though. The camming surface on the heads is the tiny little interior points of the star. I would imagine if those tiny points weren’t so soft they would be less prone to stripping out.
In what way would harder screws benefit the design? By not stripping out when being removed for maintenance is my assumption so i will go with that.
What percentage of people with this satisfy and what percentage will just want the standard stainless (303 I believe) back after having over torqued their fastener together against titanium. (fantastically grabby material by the way). People aren't going to be happy either way as they never are 100% happy.
Reason #2 to not change is the cost; The parts are already very tightly controlled..Especially the female end. It's part of the alignment structure of the whole assembly. Last time I seen the blueprint on the female side, the outer diameter was around .0002in controlled dimension.. After heat treating the parts, this is a bit of a moving target to achieve. (measure parts before and after heat treat- they change) Choices are post heat treat grinding or the old guessing game of turning them to a specified dimension and hoping the heat treat is very controlled and the majority of your parts are still in spec after.
It's not impossible to do but it is somewhat impractical.
Another factor is time. CRK is running at 100% capacity and have been for as long as I can remember. Changing processes isn't something they do at a whim.
At least, these are some educated guesses from my own experience..I'm sure there are other reasons that I am not currently seeing right now.
Crk’s screws have actually never stripped the head surfaces for me. I’m sure alot of it has to do with the deeper female slot. Also I’m not necessarily only talking about CRK screws.
But even if hardened screws were not being overtorqued. Would just the extended wear life not be a benefit. I know how grabby Ti can be on steel. We have all felt it undoing our CRK screws when they sort of “pop” off at the first turn.
Sure..you could extend the wear life by doing that..but then you run into the law of unintended consequence..Firstly, you are not choosing a fastener for it's ability to hold two pieces together, but rather it's ability to withstand torquing with a tool. When you do this, you just move what breaks..which would probably mean the tool itself. Some of the point of the engineering process is to limit breakage to the cheapest possible replacement part if that makes sense.
Those are all good points. If the idea is someone might overtorque the screw and thus the screw is better damaged than say, the ti threads on a knife where that screws into ti, definitely better the screw goes rather than the ti threads on the handle.
For CRK and knives that use chicago screws it would be less of a concern I imagine.
All I am asking is why not make the screw similar hardness to the driver bit of say a wiha tool. I guess I just will remain wondering.
Just for the sake of argument... CRK charges less for the tools than the screws as it is. I'd almost rather the tool breaks by this logic.
A good question to ask the knifemakers or manufacturers that use screws I imagine. I'm sure most will tell you that there is less benefit to you taking your knife apart than to have a hardened screw. I would also imagine that many would rather stick to what is cheap and available off of the shelf.
Now, how many items are engineered to be taken apart in the same fashion you want to take down your knife? Most things, when screwed together are meant to be a semi-permanent assembly without regard to your need to constantly take them apart..Those that aren't use different ways of fastening..such as clips and clamps.
The cost of maintaining your folding knife is being paid in the occasional replacement of some fasteners here..The more you feel like you have to clean it, the higher the cost.
This is going to be a high number, but let's say you budget for one cleaning a year for your Inkosi. The cost of the screw kit including the wrench(s) is $12.00 (plus shipping- but the total cost won't be this high or shouldn't ever be this high).
12/365= ~.03
This is going to be ~.05 on a 21, but you get the idea- Pretty cheap IF you replace the whole fastener kit which is overkill and beyond.
If you find that you need to take down your folder and this cost is too high, I am going to postulate that you are carrying the wrong tool. Perhaps a fixed blade is in order.
