- Feb 18, 2016
Excuse my ignorance but what is it in the composition of the steel that makes up the carbide volume? These threads are some of my favorites, even if i dont fully understand them yet
America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
Interesting test.
But you didn't give the steels cyro treatment.
How would that have influenced the results?
Also to me stainresistance is an important feature. How do the steels compare there?
There are a lot of steels out there without any reported toughness values. And comparisons between toughness results from one company usually can't be compared with another company, often because they use different testing methods. So we collected together an eclectic group to compare. AEB-L is known for its high edge stability and toughness but as far as I know there aren't any toughness numbers out there. Niolox is a European steel with V and Nb additions which has been pushed before as an "enhanced wear resistance" AEB-L. Everyone knows CPM-154, of course. 19C27 is made by Sandvik but has 1% carbon so its carbide volume is much higher than the 12C27 and 13C26 steels. 40CP is our representative of Carpenter powder metallurgy stainless steels. And D2 is of course the well known tool steel. All of these steels were heat treated using a cryo treatment directly after the quench followed by a double temper. I also added in the CruForgeV testing that we did as a comparison, but I'm too lazy to link to that thread. The austenitizing and tempering temperatures were as follows:
AEB-L: 1950, 350
Niolox: 1975, 350
19C27: 1950, 450
CPM-154: 1950, 450
D2: 1870, 450
40CP: 1925, 350
Anyway, AEB-L is by far the toughest, and its reputation is well founded. Niolox did not do as well as hoped. 19C27 and CPM-154 have similar toughness, around half that of AEB-L but better than 40CP, Niolox, and D2. There still isn't much out there with toughness between AEB-L and 19C27/CPM-154. There are just so many more options when it comes to non-stainless tool steels. Oh, and D2 is confirmed to be overrated.
That’s too much to reply to in a single post, I think. Verhoeven wrote about stainless steel design on page 134: http://www.hybridburners.com/documents/verhoeven.pdfExcuse my ignorance but what is it in the composition of the steel that makes up the carbide volume? These threads are some of my favorites, even if i dont fully understand them yet
People with PhD’s don’t know everything.This excellent thread let us think why doesn’t more people uses AEBL in they Knives, and insists in using D2 and other silly (in my opinion, at least) things in “hard use” Knives. The answer seems clear to me: because is cheap and associated to cheap knives (13c26 is used in pretty cheap knives) with poor heat treatment. Let us not forget PHD Roman Landes uses AEBL in most of his high performance kitchen knives.
If the charpy samples were the same thickness than the biggest difference would be the amount of reduction in forging. More forging/rolling leads to reduction in carbide size and reduction of segregation. This would show up most apparently in transverse toughness tests but would be seen in longitudinal tests as well which is what we performed. If we used full size charpy specimens from the block that would also change our values even if they were both normalized by cross section because of the change in triaxiality, but I’m struggling to find an easy to understand link to post about triaxiality to explain what I’m talking about.Hello, Larrin, thank you for your great tests.
Just curious how did you select your steel samples. Did you used Rolled sheet or flat bar with length direction parallel to the rolling direction? How do you think using a steel cut from a big block, not sheet, will affect toughness?
Ive Been reading through this all morning. Excellent information thank youThat’s too much to reply to in a single post, I think. Verhoeven wrote about stainless steel design on page 134: http://www.hybridburners.com/documents/verhoeven.pdf
The 40CP toughness is interesting also because 440XH/XHP and 20CV are likely worse, and those steels have occasionally been advertised for their toughness. CPM-154 looks pretty good though.
By all indications the toughness of 3V should be pretty good. However, whether it would have superior toughness to AEB-L is hard to predict. The two have similar carbide volumes, but AEB-L carbides are smaller which should improve its toughness. But AEB-L is a stainless so the high chromium in solution likely somewhat reduces its toughness. Other interesting comparisons would be Bohler and Uddeholm grades like Vanadis 4 Extra, K490, and K890, since they show in datasheets and papers having superior toughness due to their 3rd gen PM process.Do you believe CPM-3V will has the toughness live up to the hype? or at least would it be any tougher than AEB-L?
