Centermass
- Feb 25, 2016
Medford Pretorian Genesis and 2006 queen made Schatt and Morgan 1 of 600
Are the grind finishes between the two Medfords as drastic as the photos make it appear? The first photo looks rough, while the second looks refined and smooth.
It’s just the lighting and the camera angle my friend. The grind is actually very close and similar to each other except in size. Yes they are over built and he actually designed the praetorian T to be able to pry open a door if need be yet it will still slice paperAre the grind finishes between the two Medfords as drastic as the photos make it appear? The first photo looks rough, while the second looks refined and smooth.
I know nothing about Medfords other than they look overly built and solid as a tank.
Thanks
Thanks my friend.It’s just the lighting and the camera angle my friend. The grind is actually very close and similar to each other except in size. Yes they are over built and he actually designed the praetorian T to be able to pry open a door if need be yet it will still slice paperLove Medfords there in a class of there own .
Sometime if I remember I’ll try to give you a side by side picture if I get the right angle on both to show you the beautiful grinds .Thanks my friend.
That's some neat CNC design on the modern micarta. Do you notice it in hand?
No but it definitely does add some grip.That's some neat CNC design on the modern micarta. Do you notice it in hand?
ThanksSometime if I remember I’ll try to give you a side by side picture if I get the right angle on both to show you the beautiful grinds .
