- Nov 29, 2006
Back to current. Great info here!
Phillip, much of "control of carbide size" starts when the steel is made .Compare for example, 154CM and CPM154 .154CM is conventionally made with larger carbides ,and CPM154 made with the CPM method with smaller more uniformly distributed carbides. In the higher carbon steels you never dissolve all the carbide originally there. You may move it around and create serious problems [continuous grain boundary carbide] but it's still there. Proper HT dissolves carbides until the matrix is saturated with carbon .That matrix is turned to martensite and on tempering produces very fine carbides .Some of those carbides will have coherency with the matrix for even more strength and the carbides give wear resistance too. Those are the "many very tiny little chromium carbides"
Simple steel -- simple temper. Plain carbon steels a single temper for one hour is fine. For a S30V I'd do a 2+2+2 temper.......EDM - make sure you ALWAYS temper after EDM [not before] !! I spent a lot of time in the early days of EDM explaining why their EDM dies cracked ! EDM vaporizes steel and the remaining surface has been heated high enough to produce Austenite and untempered martensite !!
For those of you with the time and interest, John D. Veerhoeven PhD has written, and generously posted (in .pdf format) for free, a book entitled Metallurgy of Steel for Bladesmiths & Others who Heat Treat and Forge Steel. I am in the process of reading this book, which is written for Bladesmiths and Blacksmiths, and it's quite fascinating. I strongly recommend it to everyone in the forums.
It is now under copyright and available for purchase through ASM. There is at least one place on the internet that still has the free version, but I don't know if posting a link to that would be proper now that it is copyrighted.Anyone know if this PDF is still available online somewhere? i just tried to look at it, and the file no longer exists on that server
Thanks,
-Page
Thanks,
-Page
