Mete or anyone else.
Tonight I did a bit of work in the forge.
I hammered down a 1& 1/2 inch Load Shaft into a blade. The blade is still connected to the shaft and while I was working down the tang, I decided to try that cold-oil quench this time as an experiment.
I heated to non magnetic near the finishing of the tang, then heated it a bit hotter, then ran outside to the 6inch wide/ 3 foot long pipe I have filled with mineral oil and jammed the blade/shaft down into it.
There were tons of smoke, but no fire this time.
I did this same thing 3 more times as I finished the tang.
I then normalized, then placed the heated blade in Vermiculite to anneal over night.
Comments?
I still have to cut the blade free of the rest of the shaft in the morning, and there will be a bit more with the forge and hammer. Here is my question.
I have a clear idea now, based on what you experts tell me about the very importance of the last heat treatment before the actual heat-treatment and quench to make the blade edge hard.
I wish to do this next to last heat treatment the correct manner so as to set my self up later better.
QUESTION: What do you suggest is the best way to do the heat treatment that comes just before the real hardening of the blade treatments?
Also, to heat the steel when I quench to harden the blade I use my forge. I heat to non-magnetic, then race to quench before it can cool at all.
But I also hear much talk about allowing the steel to sit for a few moments at the right temp.
My last question,
QUESTION: , do I have to wait with the final heating of the blade before the last quench, or can I just heat to non-magnetic and quench right away?
