- Sep 9, 2003
I was recently doing some testing on an oil hardening alloy of .5% carbon content and had some troubling mysteries thrown at me. When marquenching/martempering other alloys I work with (e.g. O1 or L6) I get very consistent as-quenched Rockwell numbers and have a predictable variation of one to two points less from a full quenched piece due to autotempering effects, which will then level out to match up fine after subsequent tempers. However this other steel was giving me a much larger discrepancy from martempering giving much cause for concern on achieving full hardness. The steel is well suited for martempering yet I was more than 4 points lower from that treatment! This is the sort of thing that will make me into a baggy-eyed monster from lack of sleep. I heat treated and re-heat treated looking for some clues; I didn’t have time to do any metallography so a look at the internal structures are not a tool at my disposal this time. Why is martempering so successful with my normal steels yet failing on this new one?
Then last week while cruising on my motorcycle down to Tim Lawler’s shop, I found a wonderfully winding riverside road and just zoned out taking the curves. In that relaxed yet focused state of mind all the metallurgical data just sort of flowed in and out of my head and as I came out of a curve I suddenly reversed a stream of information and focused on some numbers. BINGO! It was like a stroke of lightning when I saw it clear as day, and I also felt like a damned idiot for not seeing something so obvious before then! I did not abandon logical use of metallurgical data for some new form of biker bladesmithing, but here is a challenge to explore the difference- Can one find the same answers without all this horribly misleading, evil and soulless metallurgy?
Here is the information available- You have three steels, one at .9%C, one at .75%C and the other at .5%C, all have enough chrome to be fully oil hardening yet the last one shows a marked drop in hardness using the same quench i.e. heated in high temp salts and then quenched into 420F Thermoquench salts until equalized and then allowed to air cool.
If one dabbles in all this useless and destructive metallurgy all the information you need for your answer is right there, and while some may call it “science” and go all tin foil hat about it, really it is just common sense and applying data to solve a problem, that is no more “scientific” than working out that adding 1 marble to 2 marbles gives you three marbles (until you loose them all from dabbling in such dark arts).
But I am curious what answers can be gleaned without the use of any metallurgy at all. No curves, charts or graphs, no discussion of phases or microstructures, and although it is not fair, folks like Mete and other academic or technical types are not allowed to try since they are part of the great scientific conspiracy. No copping out by simply writing it off that martempering is itself "scientific" thus without it there would be no problem, various forms of the same techniques have been used for centuries (interrupted quenching) and would give similar issues.
Some could wonder what my point is or the relevancy? I think it is very much on topic and such conundrums are faced by knifemakers every day, and I could do a dozen more threads with other puzzling issues we constantly face. In all my years I have yet to find any tool that has been more useful in saving troubleshooting or time planning or predicting than metallurgical information. So I am incredibly curious to see how things can be done in other ways that do not include it.
