it's not my JK, but i was next in line
if you look the water line is just below the intake. it sucked in water and hydrolocked
+1...... :thumbup:
Then I have one of these to play with.....
Mine has a camper shell on it and is OD Green....... for now.
M 1028 CUCV 5/4 Ton
1985 K30 pickup / J code 6.2L diesel / TH400 3 speed automatic / NP208 transfer case.
Dana 60 front axle with limited slip
Corporate 14 bolt rear axle with Detroit Locker
4.56 gears
This was my 77'. The older stuff is easy and fun to work on if you are able to. But for me not practical.
The Unimog definitely does not suck.
What exactly do you plan on doing with it? Off-roading? What type? Slow? Fast? Mud?
Unless you're a carburetor fanatic, I recommend sticking to something with EFI. You've got tons of options... time to make a list of the things that are important to you and go from there.
I'm a big fan of 87-96 Twin Traction Beam Fords. An EFI 302 is still capable of relatively decent mileage. They can be made to work extremely well off-road (fast, rough stuff). Broncos are essentially the same thing. They can be stupid(scary)-fast in the rough.
Explorers and Rangers are basically the same thing only smaller. In my opinion, the 4.0L Ford is one of their best engine ever. They run clean and well forever and make great power where you need it. The auto transmissions can be weak if not maintained and kept cool but I've had good luck with them. The 5 speeds hold up really well. Best of all, even with lift and tires, the 4.0L is still capable of 20 plus mpgs on the freeway.
TBI Chevys are good and easy to work on. I would stay away from the independent front suspension trucks unless you only want a street queen. K5 Blazers can be had with TBI and solid axles... great combo, cheap parts and easy to work on.
Landcruisers are great. They can be expensive to modify and work on (or pay someone to), but they're Toyotas....
I could go on and on. Give us some specifics on what you want to do and we'll give suggestions accordingly.
This is my truck:
1984 Bronco with Autofab suspension
Your Bronco, is really great!
I drive this and love it but...
I am terrified of repair bills. $8k tranny $20k replacement cost are freakin retarded!
I think its a great rig. Great offroad. The v8 is a nice 310 hp but mpg ranges from 20 to 8 depending on how you drive it.
don't think i'd ever recommend one cause of the cost of repairs.
