I just replaced the broken stock omega spring in my mini-bugout with the Pacific Sons omega springs. They are noticeably thicker and the increased force on the lock bar is noticeable. IMO, the only issue is the increased friction between the lock bar and blade tang, when the blade is pivoting. I have been using Blue Lube on the blade tang, lock bar, and omega springs, but it hasn’t been very effective.
If I do get a significantly longer life from the thicker springs, I think the trade off will be worth it.
I think it is worth noting that fatigue life is significantly affected by scratches on the springs, abrasion, or corrosion is going to significantly reduce the fatigue life. So, while the materials used and the spring thickness matter, they are not the only variables to be concerned about.
If anyone can recommend a viscous oil or grease that works well to protect omega springs, without bunking up the knife, I would be much obliged.
