- Dec 27, 2013
Thank you everyone, I wasn't expecting quite so much response.
unwisefool - The edge seemed pretty good for a chopping tool. It wasn't tested extensively, though I did spit some boards and chop on a table leg (which is easy for a blade anyway), and dropped it on its tip onto a concrete floor, without any real damage. It seemed quite tough. I hope the blade's owner will use it a bunch, then report back and send the blade in for some final tweaking. In the meantime, I'll do some experiments with heat-treating this alloy, and if the results are good I'll apply it to this turbine blade. In its current as-forged condition, the edge should preform at least as well as a normal steel agricultural tool like a machete, though this blade is a lot thicker. As it is, the blade is so rigid that it rings like a bell underwater.
Ronin_Jedi - This stuff would make a great hatchet head. When I use a ti blade for chopping tool purposes, the main difference is just that the light weight makes it so easy to control, accurate, and quick, as well as amazingly non-fatiguing to use. It still cuts great, and the spike of force on the cutting edge is still acute when you chop. The lack of extra inertia seems like a good thing to me, though I'm sure that could make for a raging debate!
BFS - If you like convex edges you should check out JW Bensinger's knives and full-on swords. I do like a nice thin convex edge. Another raging debate!
