Thank you all for the comments.
Today I worked on the guard and collar
That is the guard
Taking some meat of the collar
Getting there...
Preparing for milling the slot in the guard
Checking the alignment of the vise
Ok, the blade has 5,40 mm at the recasso, I used a 4 mm bit.
(Note: I never actually learn how to mill, I just got the machine and tried it until I could do something decent)
I take 0,25 mm per pass, so it's a rather slow task, fortunately I had Led Zeppelin to help me endure...
(I think NASA uses this same cooling system for their milling operations...
What do you know...5,40 mm also
After sanding
It turn out that the slot was a bit smaller in some parts, I am not at all a good milling operator, so I had to file a little bit the slot, and it turn out that some parts now where to big... I use to belive that that problem was unsolvable, that's why I use to file all around the shoulders and tang, and make the little step.
But a few month ago, a friend of mine gave me a solution, it was one of the greatest tips I ever got, so here it is. Sorry if you know it and is not big deal, but for me it was LOL
There you can see the gap I was talking about
And here is my solution
With a dulled center punch I tap it lightly all around the gaps, creating a burr. Then present it again in the blade, and the burr copies the shape of the tang, and close everything beautifully.
Then I went to the surface grinder to take those little holes, they are not at all deep, so it's really fast
A little hand rubbing in that
And you can see how it is now, the gap is almost gone, I have a little more work to do tomorrow on this part but it is almost ready.
Thank you Mariano Yanonni for the tip!
I continue tomorrow...
