the possum said:
WYK-
For your kind of use, it doesn't sound like you'd see the difference or need the extra toughness offered by 3V. But when I sharpen my bowie, I use a 120 grit alumina stone, and remove metal so quick the blade actually gets hot. That's how much damage it gets. It would take a month to sharpen it with a strop. According to the chart, 3V or S7 may well reduce this damage significantly, meaning my knife will last longer. I've already removed a quarter inch of steel from the last third of its edge.
3V is likely the best steel for any sort of knife that will take a beating and needs to hold a good edge.
However, I only use my Bowies for one thing - hunting and self defense. I don't camp with them, per se. I mean I use other tools for wood, making spikes etc. A custom 52100 13" bowie is made to kill animals and people - not sticks
For sticks and splitting I use a 5160 axe with a full flat grind that I ground out of a huge billet a forging bud made a short while ago and did a differential heat treat on(hard, soft, hard). I'm a big guy, so carrying 6lbs of tools into the woods is an easy chore, and I get tired of the woods after afew days(basically cause I live in them to start with) so I rarely camp so long I consider leaving tools behind to stuff more food or provisions into the backpack. So, when I am sharpening my Bowies it is usually after it's killed something or done some cutting my 5.5" hunting knife(also of 52100) couldn't do on a hock or some such. It's just good fun cleaving the leg off of an animal in one stroke with a 13" Bowie for the BBQ that evening.
I can go an entire season and not have to sharpen it, though. And it still gets plenty sharp by stropping. I've not had to grind it out, yet, either. My brother has a 10.5" hunting Bowie I ground for him out of 154CM and had hardened to 59 RC. It has a 1/4" thick spine with a full flat grind on it's 2" wide blade. That thing sees less work than my 52100 Bowie does, and it is much more of a chore to sharpen. So I'm just comparing my experiences with carbon and stainless here.
I do not have a 3V blade, but I do want to grind one sometime soon and send it to Bos. I've been getting some quotes on 3V stock, and it's expensive!
WYK
