- Sep 23, 2014
Hi,Re: cutting a nail nick-... DO NOT use cutting fluids with abrasive discs...
why no lubrication?
Hi,
Well, thats the manufacturers website, and the rest of the english translation reads like fluent/native english, so a typo? highly unlikely, all the other translations seem native , and even the "bad" machine translation say use oil for best results
In addition to that, this guy says he telephones someone at taidea who spoke english and told him use oil, and he did and results were "better" as in more comfortable shave / higher grit finish Wednesday shave and a chat about taidea hones. - caleb McCullough
- pl to en Soak the stone in water or oil to use grinders companies Taidea. ... http://youtu.be/7hond5-o6vY
- ru to en combined with grinding oil
- pt to en Soak the stone in water for 5 minutes...3. sharpness result would be much better to use to sharpen ing oil.
- cn to en With sharpening oil with better results.
so waterstone or oilstone? yes![]()
"oil is superior lubricant reduces friction and extends life of abrasive".
But speaking of soaking in oil, this buy broke his king 1k, and soaked the smaller piece in oil, it didn't explodePerhaps a happy accident on a broken stone.
---First thing noticed was cutting speed was slowed vs water---
----The scratch pattern looks much more coarse then usual micro bevels with the King 1K and water---
---Usually to remove light reflecting this takes around 40-60pps, but this took 140pps with around a pound of force since I noticed the first 20 passes were doing nothing to reduce the size of the reflection on the apex instead of my usual ounces I use.---
Not sure why you would claim "oil is superior lubricant reduces friction and extends life of abrasive".
Are you claiming oil reduces the compressive or tensile strength of steels, or increases the compressive or tensile strength of the abrasives?
You say he said, they said and is good to go. I'd be interested in what you found out when you tried it, before telling anyone they can make this work and possibly causing them to lose a bunch of $ in gear.
Did we watch the same video?
Thats some funny stuff HeavyHanded and not at all true, it doesn't even sound truthy , which one of my posts are you reading?
... while giving people advice that will almost certainly cost them money if they should follow it...
CheersAnd with that we're back to the top of page one and end of the conversation....![]()
