kgriggs8 said:Thanks for the well thought out replys. I really have not used a khukuri other than the cheap CS one that I know is not much more than a piece of sheet metal cut into the shape of the khukuri.
It seems to me that the khukuri has the edge when you have to do heavy chopping but the machete is the thing for light brush. I do about 75% light brush and 25% chopping so that is probably why I am so fond of the machete. I think I need a khukuri though because sometimes I look at a tree or really large limb and really don't want to spend the time and the effort to cut it with the machete. The mahete will cut decent sized trees but now that people mention it, it does bind in the wood and is a choir.
I have a nice medium sized ax but I think an ax is a limited tool compared to the longer blades like a machete and probably a khukuri.
Now, should I get a khukuri that is closer to a machete like the Sirupati or should I get a chopper like the Ganga Ram? I like the look of the Sirupati but I wonder if it won't be as good of a chopper as some khukuris and not as good of a brush cutter as my machete. Is it a jack of all trades, master of none type of khukuri?
Azis said:silver...
I tried different lengths of several such as sirupati, kobra, wwII, penn, BDC, chit, ganga ram (The GR was not bad almost as good as the AK ) the two Ak worked the best. The penn was the first one I tried because for some reason I really expected it to be the best. My larger WWII did ok on some branches 2 to 4 inch but it broke through the branches more than cut maybe the weight was the reason. I am no chopping expert but I have put a lot of time and work into this.
In comparison I have a small ceramic ax that chops faster and is light and easy to use. The two handed cold steel machete works real good though I think the two hands instead of one is a factor to consider, is that really a fair comparison? My standard $4 machete is fair at best but it's really for very small branches.
I also have a couple of bolos they didnt do any better. As I said I collect Khuks as weapons not tools so it does not detract me from Khuks in any way and my HI blades are far better than any other brands I have. In fact I tried a couple of my Khukuri house army service models and they just didnt compare to the HI blades.As a side note I can't get the service models very sharp and they appear to dull faster not sure why.
I would add that as a martial artist I have been swinging Khuks and other blades for a lot of years I practice on trees and logs and am pretty good at hitting the same place from most angles so my chopping is not bad in comparrison to someone that would be hitting all over the place.
Kazeryu said:I have a question about convex edges -- how will I know when I've put one on correctly? It's pretty small, and not something you can really see, is it?
Is there any way other than just sharpening, test-cutting, sharpening, test-cutting, sharpening........
Azis said:Very good point and something I need to learn more about and I need to go back to each one. However the cheap ones (non-Hi) that I don't care about I have started just using as file on them and then a diamond rod.
hollowdweller said:Is that your way of saying you are of the male gender![]()
Howard Wallace said:Yes. A couple of my friends carry combat scars from machetes.
Your wisdom is appreciated here. Please use the skills of the scholar and the poet too, to convey the wisdom in an acceptable manner.
Peace be with you, old warrior.
