- Aug 17, 2003
Alfred said:Kronckew:
fencing sabres are also not weapons, being much like a fencing foil with a better guard & a bigger target, everything above the waist counts, inc. arms & legs. & slashes as well as thrusts there count.
I beg to differ on that.
I study saber and on real duel the epe which resembles the rapier was a thrust weapon.
No edge, and if an edge was applied was primarly so the blade would not be help by the opponent.
While saber is mainly a cut weapon, can also be used for thurst.
What is better? Depends on everything Ivsa posted, mostly talent.
I had a fellow lunge and stab my right thigh while I was chopping his head in two.
Actually he fell on his butt.
Alfred
not sure what you are differing on, i said that the sabre was slash & thrusts, the fencing sabre has no sharp edge or point, it's all make believe, and i know the epee hasn't got a cutting edge, it's all point & thrusting, tho getting slapped with one still hurts. if you were stabbed in the thigh during a sabre match, it didn't count as that part of the leg is not a target. not sure why he'd fall on his butt unless he tripped. all three fencing weapons have either rubber bulbs over the flattened points or a flat contact area & micro-switch. the fencing sabre is very flexible & whippy (and also stings when you get slapped with it) if you are taking about scaa type duelling with blunted full sized weapons & armour, that's different & also a bit phony, if you're talking about heidelburg styleized duelling mostly intended to produce a nice trendy scar across the face, or using real sabre, you are not long for this world i think.
to be more specific:
During the Middle Ages (5th century to 15th century) the sword was an offensive weapon used for cracking armor, and the shield was used as a defense. After gunpowder came into general use, heavy defensive armor became obsolete, and the sword became a defensive as well as an offensive weapon. In the 16th century the rapier was introduced in Italy, and the art of fencing was rapidly systematized in fencing schools. A dagger in the other hand, and later a folded cloak, replaced the shield. Eventually the non sword arm was left free and held away from the sword arm to minimize the target area.
The use of the rapier and the Italian fencing technique spread throughout Europe. In France and England, the size and shape of the rapier were constantly modified because its length and weight made it clumsy to carry. During the 18th century the small sword, or épée, was invented and popularized in France; the new weapon resulted in distinct Italian and French styles of fencing. The Italians used the rapier in a bravura manner, with pronounced, vigorous gestures. The French used the épée in a more formal manner, with great restraint of movement. The French style of fencing became by far the more prominent. Its rules govern most modern competition, and the vocabulary of traditional fencing is composed largely of French words.
In the 19th century dueling was generally outlawed, and the fencing schools turned to teaching fencing for purposes of sport. Much of the equipment still used by fencers was developed at this time, including the glove worn on the sword hand, the plastron (chest protector), and the mask of wire netting.
[FONT=Verdana, Arial, Helvetica, sans-serif]T[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]hree weapons are used in the modern sport of fencing: foil, épée, and saber. The blades of these weapons are made of tempered steel, and each has a maximum blade length of about 89 cm (35 in); the maximum weight of foil and saber is about 500 g (about 17.6 oz), that of épée about 770 g (about 27.2 oz). Developed originally as a practice and sporting weapon, the foil is light and flexible and is considered the basic weapon. Its use is generally taught to all beginning fencers. Touches are scored by thrusting with the blunted point; the blade is rectangular in cross section. The modern épée is descended from the French small sword. Like the foil it is a thrusting weapon, but has a larger bell, or hand guard, and is heavier and more rigid in construction.[/FONT]
[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Handles, or grips, for foil and épée vary and are chosen according to individual preference. They include the French grip, slightly curved and with a pommel at the end; the Italian grip, which has a crossbar and is used with a wrist strap; and various pronged handles gripped much like a pistol.[/FONT]
[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]The modern saber is derived from the weapon formerly used by cavalrymen. It has a protective, scoop-shaped hand guard that curves under the hand and, like the épée, a blade roughly triangular in cross section. Touches are scored by thrusting with the weapon or, chiefly, by cutting in a slashing motion with the edge of the blade.[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Tactics vary among the three weapons, but certain fundamental techniques are common to all. Motions of attack and defense are initiated from the basic on-guard position, a crouch assumed with both knees flexed, the rear arm crooked upward, and the sword arm partially extended toward the opponent. The basic attacking action is the lunge, executed by stabbing with the sword arm at the target and thrusting forward on the front leg. The attack is successful if a touch is scored on the valid target area. In foil fencing, only touches on the torso are counted. In épée competition the entire body, head to foot, is a valid target. In saber fencing the valid target is the part of the body above an imaginary line, called the saddle line, drawn across the top of the hips (this includes the head, arms, and torso).[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif] A movement of the blade designed to block an attack is called a parry. Fencing has eight principal parries, designated by the Old French ordinal numbers: prime, seconde, tierce, quarte, quinte, sixte, septime, and octave. Each parry is designed to protect a different part of the target against attack. A riposte is the return thrust made immediately following a parry.[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif] The fencer who takes the offensive may employ different kinds of attacks to circumvent the various parries used by an opponent. A simple attack is made with one motion that is, a cut or thrust of the blade and is intended to hit the target before the defender can parry. A compound attack involves two or more blade movements. The initial movements are feints, designed to mislead the opponent into parrying in a direction other than that in which the attack finally develops. Other techniques, such as beating or pressing the opponent's blade aside, may be used to create an opening for an attack. A running attack, or fleche, may be used to catch an opponent by surprise. A competitor under attack may also resort to a stop-thrust, a sudden counterattack made by thrusting without lunging.[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]B[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]outs are conducted on a strip approximately 1.5 to 2 m (4.9 to 6.6 ft) wide and 14 m (46 ft) long. The first fencer to score five touches wins a bout. In formal competition the weapons are wired and connected to an electrical scoring apparatus, so that when a touch is scored a light flashes on the sidelines signaling the touch. These electrical weapons were instituted to facilitate the exacting scoring of bouts. Foil and saber competitions are based on complicated right-of-way rules regarding mutual touches, whereas in épée competitions only the timing of the touch is considered. Bouts are judged by a referee who applies the right-of-way rules and awards the touches with the aid of the scoring apparatus.[/FONT]
