CVamberbonehead
- Nov 6, 2017
Another vote here for the SRK.
The Rat is on the list for sure, though I am thinking a fixed blade is the way to go... I'll check out ESEE.How about an Esee fixed blade or that Rat folder ?
For a ultrabeater on a budget a ESEE fixed blade is hard to beat imo ...
Frc505
Esee is going to be way over your $50 budget. The Ontario SP series is damn hard to beat for what you’re looking for. I’ve had an SP1 Marine Combat for over 25 years that gets rough treatment and it’s still going strong.The Rat is on the list for sure, though I am thinking a fixed blade is the way to go... I'll check out ESEE.
Yes it is over 50 bucks but the rat folder in d2 can be had for around 50 dollars that is what i also suggested along with the ESEE line of fixed blades ! Especially the 5 and the 6 coming in at .25 (the 5) and .188(the 6) respectively and in 1095 high carbon steel with their heat treatmentEsee is going to be way over your $50 budget. The Ontario SP series is damn hard to beat for what you’re looking for. I’ve had an SP1 Marine Combat for over 25 years that gets rough treatment and it’s still going strong.
Yeah, 14C28N might be the ideal steel for what I'm looking for. Either that, or something like AUS8-10. It just needs to be cheap, tough, and preferably have some level of corrosion resistance. I like the Ruike idea...The price on this one is a little higher but it's a great knife and it comes with a decent sheath. The Ruike Jager F118 looks nice, feels better in hand than I thought it would, and is made of 14C28N. That means excellent corrosion resistance and much higher toughness than D2. The 8-direction rotatable clip with button lock seemed like a gimmick at first but I've come to appreciate it. It is a common feature on fixed blades from Ruike and Real Steel.
Hyde is a long established mfgr of tools for the drywall and plaster trades. I’ve used and liked them for years, in fact I’ve got an old 6” finishing knife that’s worn down to super flexy, great for skim coating skylight wells.…a leather handle hacking knife, made by a company called "HYDE". They're built for the kind of.... use... your brother puts his tools to.
I’ve seen hacking knives, also sometimes called bench or side knives, from Stanley (probably imported now) and other mfgrs. I have made my own from worn out planer and jointer blades. They’re typically chisel ground (beveled on one side only) and used on the jobsite like a small froe. Supposedly the original use was by glaziers for removing hardened window putty, but they lend themselves to many other uses as well.
Used ones are often mushroomed out on the top edge from beating with steel hammers. If you get one like that, grind back the mushroom so it doesn’t chip off and put your eye out.
Parker
