Why? I find the action to be flawless.
The only way I could see improvement is by adding an axis lock.![]()
So which one would fit on the Southard flipper? I'm looking to see if there's a way to upgrade my Southard.
You will have to take apart your Southard and take some measurements, but I don't think it will help much. I can't imagine these bearings being much of a step up from the ones already in the Southard.
I don't have anything to measure it... I have taken mine apart, and I thought maybe having all of it being SS instead of SS and plastic.
When I replaced the (much larger) ball in my manix 2 xl, I used a ceramic ball bearing. These are a step up from steel in terms of roundness, harness, smoothness, and trueness to spec size. You may be able to find similar bearings in smaller sizes to upgrade knives with similar bearings (loose bearings in a race)
The ceramic bearings are EXTREMELY smooth, they almost don't need any lubrication at all. I find they work best with a light machine/sewing machine oil, or tufglide. But overall they're so smooth they really don't need it. Because of the high hardness, you're unlikely to get any rough spots.
And the "washer" the bearings are contained within is referred to as a bearing race =]
In a pocket knife, ceramic bearings shouldn't need lube at all, the coefficient of friction is already very low. It will only attract dirt and stiffen things up. Just blow out the pivot with compressed air now and then to keep the pocket lint and dirt at bay. As far as the bore tooling, you should use 2 endmills for a good precise fit. One to rough plunge to say .015"-.030" undersize and slightly shallow and one right at finish size and depth. Ideally you would use a smaller endmill in a CNC and circular interpolate, but it sounds like you don't have that capability. A good source for small steel ball bearings is radio control ball-bearing servos. I'd imagine they can be had cheap as dirt used.
