Generally speaking,
Titanium is softer, more elastic and sticky
Steel(after HT) on the other hand, is harder, stiffer and not sticky
When getting worn, steel gets worn down and flakes or burrs
Titanium on the other hand, being sticky and more elastic, won't get worn down as fast.
Being softer, Titanium is no good for impact or denting, it get squeezed and smashed.
In the case of lockbar design, it all comes down to one thing - geometry of the lockbar and matching blade tang.
The way how Mr. Reeve did it was designing the slope of blade tang as well as the lockbar head with a very shallow angle (and matching of course), so shallow that when pushed, the lockbar could go from 40% to 70%, or maybe 80%. Yet no or very little visible wear is caused even over a long period of time, because no sharp impact was caused to the lockbar head, and the lockbar head itself was torch burnt to have a thin layer of TiN and TiCN, which increase the surface hardness and surface wear resistance of the lockbar. This hardened surface does two things :1. prevent the lockbar from wearing, 2. prevent the lockbar from sticking to the tang.
Another thing is, RIL on the sebbie has an incredible large contact surface. This large and flat contact surface makes the lock more secure and prevents excessive wear.
Anyways, long story short. When i took down my RIL military, what i found was, with the curved and steep blade tang, every opening would cause the lockbar head to dent more and more, forming an unpleasant triangle dent, any RIL military owner knows what i am talking about. This is exactly the kinda wear we are discussing here, not exactly caused by physically "wearing", but continuous and repetitive impact. what makes this more severe is the fact that C36's blade tang slopes up, leaving a rather narrow spot for lock engagement. If this continues to happen, the lock would eventually wear out, although it get slower and slower. utilizing a steel block is great, but on the other hand i would suggest that spyderco redesign the geometry of the blade tang of the military, that will even further extend the lifespan of the lock.
hope i'm not making no sense.
