Useless Knives
Have you ever bought or been given a knife that turned out to be next to useless? One I recall was back when I was on a shilling a day I was issued a beast called the M.O.D Jungle Survival Knife. It was crude, heavy and blunt. The blade was 7" long and 5mm thick with no taper. I could never get it sharp and neither could anyone else.
We already had a Golok for heavy work and I carried a Ka Bar and a Buck 110 for all my other needs. I picked those up whilst on exchange in the U.S. and they were great. Even I could get them whisper sharp.
The M.O.D knife was just deadweight and I hid it away in my footlocker.
So, what knife didn't work for you?
Many moons ago Cold Steel offered a small version of their Tanto series, but with a dropped point and more of a hunter configuration. I still have it, but it has never been used. Great size and blade shape for it's intended purpose. But, the handle is just too short and too small in diameter for me, making it very clumsy to use for field dressing and skinning.
Cold Steel? Tanto? How about their tanto Spike neck knife??
Now THAT was a user... (So much so I even paid $15.00 for the "normal" Spike) :rolleyes: What was I thinkin'????
CRKT point guard.
Took forever to get a decent edge on it, and it didn't hold it for sh*t.
I've never used a crkt again.
Pete
The CS Spike has only one use . . . to be grasped in the "icepick" grip and used to poke holes in an assailant. It's sturdy enough that it won't break if it connects with bone, and if you're strong enough it can -- and will -- penetrate bone (but then it will likely be stuck). It is a passable defensive "hideaway" shank, but is utterly useless as a utility knife . . . the CS "Mini Culloden" is far better in both capacities.
MY vote for the "most useless knife" has gotta be the strictly prohibited "Pilum Ballistic Knife".
Back in the mid-80's, I acquired a used one. This was the version with the lever-style catch. The "sheath" was an aluminum baton, and it had no safety device whatsoever. The idiot who owned it previously had spraypainted the blade black (now peeling off) and somehow damaged the coil spring. Don't know what steel was used to make the blade (tool steel?), but it absolutely would NOT take an edge.
In order to "load" the knife, the blade is slipped into it's protective baton sheath and the coil spring sticking about a foot and a half out of the handle is slipped into the hollow stabilizer tube. Next, the baton is pressed into the ground, the lever is depressed, and you lean your entire body weight onto the device to collapse it before releasing the lever to lock it in place. If the lever is pressed, bumped, dropped, or leaned against, the baton-encased blade will suddenly -- and explosively -- be released. Did I mention that there was no safety on this thing? Not sure how, exactly, the Spetsnaz and KGB carried these things. . .
Anyhow, the first few times I tried it, I thought it was pretty cool -- the blade would shoot almost 30 feet and stick. From 10 feet away, it would blast right through both sides of a hollow-core wooden closet door! Far more power than I could generate from a thrown blade. Then, after about the 3rd or 4th shot, SPROIIIING!!! I look down and the blade is danglin' from the end of the spring like a wet noodle! Tried fixing it by reversing the spring and cutting down the stabilizer tube, but nothing seemed to work. It would fire properly a coupla times, then it would do the same thing again. Whadda piece of crap!
Eventually, an acquaintance of mine shot the blade deep into the brush where it could not be found. I could've ordered a replacement blade & tube for about double what I paid for the device, but had no source for springs, so I elected to sh*tcan it.
This was the most worthless, infuriating, and dangerous (to the user) knife I have ever seen. :thumbdn: :thumbdn: :thumbdn:
I have since seen an "improved" version which utilizes a dual peg hilt which must be manipulated to slide out of a groove in the aluminum handle -- far more safe and durable than the old lever-latch, but it's still illegal to possess one, even if you never take it out of its showcase (unless you remove the spring, perhaps).
My brother gave me a Stihl knife for Christmas, China made cheapie with the Stihl colors and logo, pretty much worthless, the handle to blade play is horrible and it's shape vs size makes it much more worthless, If I was Stihl I would'nt put my name on this crap it sullies their rep IMO.
I received a nice plastic handled "made in China" tactical style liner lock ( well it locks up some times and not others ) folder from an Ebay seller that tossed it in with an order to compensate for a slight overcharge in the freight.
Totally useless as a knife, but I does generate a laugh from time to time.
When friends or fellow knife enthusiasts ask to see my knife collection, I normally drop this one on the table first and guage their expression - I do get some really strange looks from them.
You guys are truly spoiled. I used to be a mall ninja long before I came to this forum so YES I have many hunks of pot metal. mostly from UC:grumpy:
HWWAAAAAAAAIII YA!
I received a box of 12 made in China stockmans on a bulk purchase on E-bay. Opened one up to look for blade play, which was awful and was able to pull the bolsters apart. Dropped the whole box in the trash because I did not want anyone to get hurt.
I don't have any junkers, or knives so cheap that they're useless...
I do, however, have a knife that I'm nearly positive will never see any practical use.
Don't get me wrong, I like it. It's pretty, and has a "neat" factor. It's a big ratcheting navaja from JJ Martinez (if I remember correctly). The blade is 6" long, and really wide. Super-pointy tip. The whole thing is 14" long when opened. There's really no task I can think of that would necessitate this blade... A knife half that size will do anything I ever need.
If I lived in the 17th century, and wore a sash around my waist instead of having pockets, and everyone else carried a sword, I might find it useful. As it stands, I have no reason to lug this thing around with me, nor do I really even have a comfortable means to carry it (aside from a backpack, perhaps).
Maybe I'll get one with a 3.5" or 4" blade one day, so I can actually use it.
Peace.
Alex.
My most useless knife is a pakistani 110 clone piece of junk. I've tried and tried to sharpen it and cannot even get it to take an edge at all.
I have a few that are those logo'ed ones that you get as gifts. I wouldn't say they are useless - they sit on the shelf and try to look pretty:D
- gord
I actually managed to find a very used one of these at my relative's house--made in pakistan, and tons of bladeplay (in every direction I swear). I think it's called the "Wilderness II," but it's crap nonetheless.
That's hilarious! (Sorry). I remember reading a post (years ago) where a guy was throwing his knife at a tree, and his buddy decided to try the same thing with his MT Halo. Missed the tree and went into thick brush. I guess it was starting to get dark, they never found it again. I'll bet there are ten thousand knives sitting in the brush right now, but probably only one of them's a Halo. :D
I've got Ontario 18" Machete i haven't been using it for 3 years, edge is badly chipped and twisted so i was thinking about transforming into 2 kitchen knives :D What do you think ?
I have a cheap knockoff of a Swiss Army Knife that is made in China.
The backsprings are so stiff that you cannot open a blade without breaking your thumbnail--in fact, I had to use pliers to open them.
Cold Steel Panga Machete. It was so made and finished so crudely, it was offensive to look at; and it was so blunt out of the factory, you could use its "edge" to hammer in nails and wouldn't be afraid to miss.
Boy, that cured me of Cold Steel.
A gift...I think this counts.
Note the point of the blade in it's relation to the handle.
