Look on the positive side: a few more chips and you'll have a serrated blade.![]()
I recently bought some compound in 1 micron and it seems to work well but I only guessed on which one to buy. What micron compound do you recommend for stropping between sharpenings?Vanax is more prone to making a stubborn burr and I can imagine a production heat treatment with overseas standards can only exacerbate that.
What may be chipping may be a straightened out burr edge that deforms in use which will look like a chowdered up edge.
Stropping with diamond/cBN compound on leather will help mitigate this.
Sometimes these issues arise from grinding and/or sharpening by the manufacturer rather than the heat treatment. Some knives show improved performance after several sharpenings.
According to Larrin's data, Vanax at 61 Rc would give you about 10 percent more wear resistance than 154cm at 61 Rc, all other things being equal (edge angle, type of use, etc.), which they never are. That advantage would be like getting an extra day out of two weeks' use. Maybe a bit more if your use tests the toughness of your edge.
I think what you might like most is how much easier Vanax is to get a really sharp edge.
Thanks, the Waypoint is a great looking knife - good to know that 154CM is close to the Vanax SuperClean regarding edge retention. 3 weeks is a decent amount of time, assuming you're using it most days.
There is one Vanax, “Superclean” is the branding at the end of all of their PM steels. Elmax Superclean, Vanadis 4 Extra Superclean, etc.Does Vanax SuperClean offer a significant difference compared to the standard Vanax? Is one harder to work with, heat treat, or sharpen than the other?
That's probably about what I'm seeing. I looked at my previous posts and I started carrying the Waypoint L on April 24th, so it has actually been 3 weeks, or starting on 22 days now. My son used to ask me to sharpen his Mini Griptilian in 154CM about once or twice a month, same as with me when I carried a Griptilian or Mini Grip every day with something else as backup.
BUT since I gave him the S90V Bugout for his birthday in January, I have NOT had to sharpen his Bugout even ONCE! Compared to my son's Bugout in S90V, this Vanax edge retention is closer to 154CM as I said before. BTW, when I carried the KA Inkosi in S35VN for 8 weeks straight, I would strop it once every 2-3 weeks, while I'm only just now getting to stropping at 3 weeks with Quietcarry Vanax.
This Vanax blade was harder to strop with green crayon compound applied to the strop than my 154CM Kizer-made oKnife Rubato 2 or my S35VN Inkosi was today when I had to get them back up to snuff. I didn't see any rolls on the QC Vanax before I touched it up on the Sharpmaker for a few minutes, and it also didn't take forever to sharpen like my old Mini Griptilians in 154CM did when those got dull.On Day #26
So, I did strop the Waypoint L Vanax with green compound after several weeks of use, with little effect. It's still very sharp over 80% of the blade; and just needs that 1/2" area of the belly near the tip to be sharpened after 4 weeks of use.
But rather than go to diamond strop spray, I touched it up for less than 5 minutes on a Spyderco Sharpmaker, and it's back to razor sharp again. Didn't need to breakout the Worksharp and get all crazy with different grits or anything as Iddn'tdidn't need to reprofile. I just set the rods at 20 degrees per side, and used the stock brown rod and then ceramic rod for a few strokes per side with each. Then stropped for a minute with green compound.
It was easy enough that maybe my DBK diamond spray on my new strop would have been just fine after all.
Mine got extremely razor sharp with the Sharpmaker with just a few strokes. I just wasn't getting the desired results with my green compound on the strop like I did with the Inkosi and Kizer. Weird.I also just went through and sharpened my S35VN inkosi + QC Drift this weekend, also with the green crayon compound on a strop. Both at 18 DPS, I can get a burr to form on the Vanax a bit before I can get one on the S35VN. I didn’t need to sharpen either knife really, but they seem just a hair better after the touch up. They both sharpen up great of course, but that Vanax gets sharper than anything I’ve had before, it’s a paper towel shredder now. Really loving the knife now that I’ve gotten rid of the burnt edge.
