Great experiment, Mapper.....
There are ways around a wet Bic.... I posted a video in this thread...
http://www.bladeforums.com/forums/showthread.php?t=613986
One of the comments in that thread made me wonder if perhaps some may not be thinking things all the way through. The comment about 'just trying something and saying it didn't work' may or may not have been directed at my testing, but either way it misses the point entirely.
Hey Mapper ... I actually made that comment and by no means was that directed at you or your testing. I thoroughly appreciated the time and effort you put into your review and truly hope you have others in the works. Many have commented about how useless / unreliable a wet bic is and I thought it was great that Rick was able to show us a good workaround is all.
:Rich:
Blast Match - The Blast Match proved difficult, but not impossible, to open one-handed. When I got it open, I was able to spark it (less sparks than the FR/S combo). But with my cold hand, it was difficult to keep the steel pressed against the ferro rod.
When you're opening it, are you trying to pull that tab out? If you just press against the lid away from the striker tab, the lid pops right off.
Also with the sparking, are you trying to press down with it perpendicular to the ground? Try angling it 45 degrees to the ground and press down. You'll find that you don't even have to press the striker tab to get a shower of sparks. Granted pressing the tab in conjunction with pushing the ferro rod into the striker will get you a massive amount of sparks, just pressing the rod against the striker will get more than enough to start good tinder.
mapper6,
My results with tinder-quik (the stuff that comes with Sparklites) were very different than yours. Am I understanding you correctly that you did not prepare the tinder, did not tear it open and fluff it up? If so, that may account for our different results. Honestly, I think this kind of prep is not out of the question under speedy, hypothermic, wet, windy, one-handed conditions. I can snag a piece of tinder-quik on a stick or rock or part of my pack or some such, and sufficiently tear it open and fluff it up, with one hand, in probably under ten seconds.
I'm not sure how similar the maya dust you tested is to fatwood shavings I get by shaving a stick of fatwood on the spot; your results are very different than my fatwood results. I found fatwood to work fairly well under such conditions indeed, I consider it to be the overall best tinder, natural or man-made, when all the relevant characteristics are factored. It could also be easily and quickly prepared from a stick into shavings with one hand (in the same way you light the ferro rod with one hand), in just a few seconds.
If I may criticize your approach a little:
In my opinion, there are many other equally important characteristics which need to be considered, when choosing the best fire starting devices, or the best tinders. For example, durability: is the fire paste tube subject to puncture or similar damage? [Yes] And, if so, will it be damaged by prolonged exposure to air? [Yes]
In my opinion, the risk of loss/damage to the fire paste is a significant overall factor, when determining fire paste's reliabilty as a tinder. I still think fire paste is great stuff (I used to carry and use it a lot).
4. Last resort "Hail Mary" (taped to the back of my calf with "Elastoplast" tape) small 1/8" dia ferro and drill bit.
Great thread. I think it's easy to get so in to the whole "mountain man" thing that we start overlooking manufactured solutions, but sometimes inventions are actually the product of a useful and practical innovation.
And if I should ever be freezing and desperate, I don't want to be screwing around with authentic 1800s gear. I want to be getting warm, pronto.
Better get some fire paste I guess!
