Here is the unified grit chart. https://docs.google.com/spreadsheets/u/0/d/1VaTf3MXuwuvH-QLwOci4f9B9Zhkbuu1wjoSCZIUsR-o/htmlview
I just need figure out my stones situation and I’ll be good.
777 Edge I have one last request. I know the ratings for the Venev uses the FEPA-F rating correct? I’ve always used the KME Diamonds and Shapton Glass stones.
Can you give us a estimation of the grits for each of the Ursa/Centaur stones? I have seen the chart before but wanted to hear your opinion. I also want to save it to my notes so I can always refer to it if needed:
Venev
80F =
150F =
240F =
400F =
800F =
1200F =
Thanks!
Awesome, thanks. I had another version of this chart but I like this one better.Here is the unified grit chart. https://docs.google.com/spreadsheets/u/0/d/1VaTf3MXuwuvH-QLwOci4f9B9Zhkbuu1wjoSCZIUsR-o/htmlview
Thanks, good info.I use the venev 400 for most of my work knives, fantastic grit for that! Some I will finish on 800 depending on the steel
II'm currently on the r2 still have the v7
Can't answer that for you unfortunately, all I can tell you is which ones I prefer personally. You'll be happy with the Orion set - no doubt about it, but it's much more expensive than the Centaur or Ursa. They are very nice stones, I have a set of them too. Your knives will be just as sharp with any of those 3 sets of stones.Should I just go for the Venev Orions?
That is a mistake that many make, and i'm the first to put my hand up.since this was my first foray into serious sharpening I didn’t want to make a big investment in stones until I knew what I was doing, and knew what ultimately would work best for my needs.
That's good, glad you like your new sharpener and the stones, you will only get better, every sharpener has it's own quirks that you will get used to. But one thing never changes- Patience, just take your time and don't rush, if you feel like a break take one. You will quickly grow to really like your sharpener and the results you get.Made my first trial run. The patient was the blade on an original Leatherman tool. The tip had long ago been broke off, and the blade “reshaped” on a bench grinder, not the prettiest blade. I got the blade clamped in and then proceeded to cut my knuckle while adjusting sharpening angle. Note to self - be spatially aware of your surroundings. Luckily the blade was in bad shape, so only serious damage was to my pride. Set sharpening angle to 20 dps and worked through the full progression of stones. I have to say, the stones cut quite nicely, and offered good feedback. After finishing off with the 1200 stone I was left with a near mirror finished blade that satisfactorily passed the paper test. Very pleased with my first try, and have nothing but praise for the Hapstone system and the dual sided Venev stones. Thanks to everyone who contributed to my threads, and a special shoutout to 777 Edge for all of his help.
Good info. I believe you said it’s your first sharpening system? If so, the best advice I can give you is making sure your knife is set correctly in the clamp.Made my first trial run. The patient was the blade on an original Leatherman tool. The tip had long ago been broke off, and the blade “reshaped” on a bench grinder, not the prettiest blade. I got the blade clamped in and then proceeded to cut my knuckle while adjusting sharpening angle. Note to self - be spatially aware of your surroundings. Luckily the blade was in bad shape, so only serious damage was to my pride. Set sharpening angle to 20 dps and worked through the full progression of stones. I have to say, the stones cut quite nicely, and offered good feedback. After finishing off with the 1200 stone I was left with a near mirror finished blade that satisfactorily passed the paper test. Very pleased with my first try, and have nothing but praise for the Hapstone system and the dual sided Venev stones. Thanks to everyone who contributed to my threads, and a special shoutout to 777 Edge for all of his help.
For the most part yes. Shoot me an email and I’ll send you the pic that was sent to me years ago directly from KME. It was a game changer for me.I’ve seen the drawing a line trick, but didn’t use it on the Leatherman blade since its edge is mostly straight with only fast curve at the tip, figured having the straight part of the edge parallel to clamps was best. Is drawing the line still preferred, regardless of blade geometry?
Also, one of the angle clamps sits higher than the other when in position but levels out when everything is secured. Not sure if that’s normal though.
Use a Nagura stone and rub it over the Venev under running water, it works like a charm. It conditions, cleans and refreshes the surface very nicely. There is a small "King Japanese Nagura Stone" available on Amazon that works well. It's listed as 8000 grit, it's not 8000 but it's completely irrelevant if you only use it as a conditioning and cleaning stone. Gritomatic also sells a "Bodrid Dressing Stone" which I've found to also work very well.777 Edge How do you recommend cleaning the Ursa stones?
