Stuart Davenport Knives
- Feb 7, 2022
Hello eveyone, this week I have another Verde Ranch Hunter up for grabs. Im calling this one the "Sith" hunter because of the black/red colors. One of my all time favorite tool steels, CPM M4, heat treated in shop with "cryo" quench and triple tempers for 64HRC. Blade has a full flat grind, and just like the last Verde Ranch Hunter, I have convexed the area right above the edge. It has quite the thin BTE geometry. The user will probably never need to thin the blade. The edge is a standard "V", but even with a low sharpening angle, it is a very small bevel. After grinding, I basically just sharpen at a VERY low angle, the spine just above the face of the stone, and then I go back to the grinder and blend that transition, so you end up with a "tear drop" shape from spine to edge. It cuts amazingly well, as you can imagine. All grinding is done under flood, and sharpening is by hand on stones. The blade also has a hand rubbed polish, which is quite the chore for 64HRC M4. The handle is black micarta with red liners. I used corby bolts (as well as epoxy) to secure the handle. You would have to grind down to the tang or drill the bolts out to get these scales to come off. Final sharpening was just a few light strokes on a 1200 grit Atoma diamond plate, and then stropped on leather with white compound. The edge is very very sharp, and very very aggressive. If you like PM steels at high hardness and THIN grinds, you have come to the right place! Thanks for looking!
OAL: 8 7/8"
Blade: 4 1/4"
Handle: 4 5/8"
Thickness: 0.120"
Steel: Crucible CPM M4 64HRC
Edge: 13.5°, 9 micron stropped
Price: SOLD (includes kydex sheath)
Paypal preferred (samuraistuart@yahoo.com). Generally, the first person to send PP gets the knife. If you are interested, I recommend posting something like, "I'll take it! Funds sent." and sending payment immediately. No need to ask if it's still available. If there is ever a conflict, which hasn't happened yet, I will refund your PP immediately. I also take Venmo, DM me for the address, it's my wife's account and I forget the address. All knives come with free shiping in the USA and a lifetime unconditional warranty. I'll repair or replace, pretty much no matter what. Just understand that I like to use thin stock, thin grinds, and temper most steels for a slightly harder blade than you might be used to. I highly advise do not try to cut throught nails, bone, frozen food, or stab a car door, things like that. Just use it to cut stuff, like it was intended. If you have any questions, send me an email or DM me. Email is same as the PP address. Thanks for looking!
OAL: 8 7/8"
Blade: 4 1/4"
Handle: 4 5/8"
Thickness: 0.120"
