- Oct 20, 2008
I like my vertical a lot, too. It's 10" pipe with 2" of wool. I'll be making a bigger one when I can afford more kaowool, longer billets need overlapping welding heats in this one.
I made my last one with a piece on 14" industrial stainless chimney. 2" thick with a stuffing of rockwool between two .025 tubes of stainless. I the put in an inch of wool covered with satanite and ITC 100. worked great and only weighed about thirty pounds. When I relined it with castable and it now weighs like 150 lbs. takes longer to heat up and don't get any hotter than it used to.
Bill, that's a great idea using double wall stainless flue pipe! The castable not so good.![]()
Bill, the light weight stuff will work much better.Don, It actually worked really good. and looked cool too, polished stainless forge. when I cast it I used mizzu 3000, but if/whenI redo it I will use the super light weight refractory like the make the soft fire brick out of.
