Spaceghost, I've been going free hand without the gaurd. It only took a moment to realize it was too wide, although my cold steel machete is thin but would not draw properly either. Ill just have to use the sharpie to get my angles. Honestly iv had better luck with my 1x30 on larger blades. My machete cuts paper easily....almost newspaper. But the 600&1000gr micron belts blew apart, even though they're from the same distributor. So im saving for 1×42 to get x-weight belts. Even though the worksharp has thick cloth backed belts, some have been blowing chunks and all wore out way too fast. I believe this is why I had no luck with the siru. Just too worn out, only on small knives with little usage to be cost effective. Even when new it struggled with vg10 and only worked effectively up to aus8. This 5160 should have been butter for it.
So ill try my 1×30, going 400 grit to leather. Still, I wonder if these come with a micro bevel or full convex. The sharpener included (missing on my siru, so not an option anyway) only work with micro bevel. So was the original design that you just started a micro bevel in the field until it didnt work anymore, then return to the kami for a new convex, or did it come with a micro bevel.
No big deal either way, as im set up for convex, just wondering.
