SharpBits
- Apr 26, 2002
Soon, I hope!You need Carbidized Titanium to cut cardboard with high performance.
I went through all your posts and couldn't find nothing about double layer cardboard. Now you decided to mention this after 4 pages.Outpost76 is using single layer cardboard as far as I remember, I used heavy double layer cardboard.
So there you go. The only logical conclusion would be there is something about the cardboard you are cutting.I generally do not have any problems regarding edge retention except with cardboard.
I don't know about 'sharpening for cardboard cutting'. Is there a special way to sharpen for cardboard?But I do not know, maybe there is a problem with my sharpening for cardboard cutting.
I use a boxcutter.
I sharpened a S30V Shaman, 1000grit Diamond on a guided system (17dps). There definately is a burr right off the system, there is no way to avoid that. I did very light strokes in the end to minimize the burr.
Then I cut approx. 25ft of heavy cardboard
That was the point the knife stopped shaving armhair cleanly. The edge started to reflect light. It was still able to cut phonebook paper quite good.
So; looks like it is at least one of the things I wrote - nasty cardboard
I wonder why you don't do a cutting test with a ''normal'' cardboard as Outpost76 is using? Then you can compare the results and see if the only problem is cardboard or there is also something else.
I just sharpen my EDC knives the way as I usually do and use them to cut whatever I need to cut.
I don't do progressions ... usually one diamond plate (#240, #320 or #600 - depends on my mood) and a strop (usually 3um or 6um).
Well, Outpist76 is using pieces of thin cardbord and counts cuts till the knife does not shave and slice a paper. 100 feet of sliced cardboard is a 100 feet no matter if you cut a box or pieces of cardboard.A small piece of flat thin cardboard is a bit different than taking down a box in my experience.
Huh; that's true ... good point.It's only true unless it isn't. Over the course of shipping, boxes get dirty, beat up, creased, damp, sticky, or even oily. This creates inconsistencies which can affect cutting.
Different boxes also vary in thickness and consistency. Some are coated on the outside, or soaked in wax to make them harder. I could go to the store and buy a flat stack of cardboard file boxes, and cutting them up would be different from slicing up a bunch of random boxes from the back room of a grocery store or some leftover boxes from various online orders.
That flashlight trick does indeed work!
I usually can feel it as much as see it but I had a spot the stone wasn't touching yet that was a little harder to feel the absence in that one spot vs the whole edge. With the light I could see the missing spot and kept going.
I will most likely use feel for the most part and maybe confirm with a light or check for absence after deburring off my first stone with the light
Perhaps you need a brighter light, in a dimly lit room?Yeah it's really neat. There's definitely a huge benefit to actually seeing a burr over just finding it by touch. Feeling something and actually seeing it are two completely different things.
The problem I'm having with it is that I can definitely feel burrs which are small enough that they don't show up with a flashlight. I was wondering before if this was just because I have a really good sense of touch or if this was normal. That's why I asked before to hear other people's experiences. Unfortunately nobody gave me a reply to that question. It seems like judging from your post that I actually might have an abnormally good ability to feel a burr. Or maybe it's just that you aren't confident enough in your sense of touch, so you are doubting yourself without the flashlight?
Indeed.I agree however that a burr will eventually be too small to see, even with a bright light.
