- Jan 11, 1999
The problem has arisen again, I don't know if it had truly gone away when I originally thought it did. No matter what I seem to do, when I tighten the pivot screw as much as I normally would tighten it prior to any of this, my Sebenza becomes almost unopenable. The basic principle of the pivot bushing is to keep the handle slabs are certain distance apart, and to ensure smooth action, right? The only way tightening the screw more would actually make the action tighter is if the pivot bushing were actually smaller than what it should be, correct? As soon as I loosen the screw a little bit, the action is perfectly smooth.
Django606,
Your case is quite puzzling. I'm assuming the following:
- The Sebenza to which you refer is the large micarta classic you mention earlier in this thread.
- No components (bushing, blade, washers, etc.) have been swapped out from the ones that were present since receiving the knife from CRK in April.
- Since this recent occurrence of you noticing the binding of the pivot, you've disassembled, cleaned, and lubed the knife, and you still have binding.
Best regards,
Dave
