I am well aware of the steel snobbery here on BF ... Heaven forbid someone make a blade out of a steel with unknown properties and post a vid of iton a "survival gear" sub forum ... I think it is a great exercise in using what you have in a pinch.`Lawn mower blades do actually cut...
And here's wear you miss the point my friend.
The knife making Video, and the end result was fantastic.
The Bottom line is the finished tool is an unknown commodity.
For a few Dollars, and little study, a known steel could have been used, the HT and temper optimized, the maker could even dial in the hardness he was after.
Unknown Steel?
Some steel can't be hardened worth a damn, but I suspect a LM blade will harden to a point.
A low carbon steel might make a tough chopper, but lack edge retention.
A higher carbon steel might work better, but left too hard it could be brittle.
I give the maker a thumbs-up for taking up the challenge,
...but spending that much time and effort on an unknown steel when $10 spent on a piece of 1095 would have stacked the odds on creating a real hard working tool just makes sense to me.
That said, I made a few blades from unknown steels before I knew better.
Now, when I make a knife, I have a very high chance of making a knife that holds up in real world use.
Big Mike
