- May 18, 2009
Nice video Aaron. I think you got as many views on it in two days as my hand sanding 101 got in a year, LOL.
Couple thoughts/suggestions:
While I appreciate a cool gizmo more than most... Your hand sanding block is cool, but personally I wouldn't want to use it because of the time needed to change paper (versus simply moving the strip) and the ergonomics of it.
I don't think the 800X step is necessary.
On your final pulls... a block with just a touch of give will get you the nicest finish with the least amount of time. I have found that an 80-90 durometer urethane is the best mix of hardness with just a little give. Also, you can do a pull stroke, and then do a push stroke through and out of the plunge... that gives an uber clean finish. You want to hold your upper body fairly rigid and pull from the waist.
All of this is just in my humble opinion...![]()
Rubber gasket material in the plumbing section at Lowe's/Home Depot is perfect for this
