Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
Perhaps a silly question, but:
Would cooling a platen actually keep heat build-up down while grinding a blade?
I reckon I could understand it better when using a very thin belt like a J-Flex or some such, but with a 50 grit ceramic belt......would it really help?
I've never felt the belt after a session of grinding....I know the platen gets hot, but does that heat transmit back through the belt?!?!
I don't think that is a silly question. It is my expectation that cooling the platen will help the belt last a little longer and reduce the heat in the work piece, but only to a certain extent. It might reduce the built up crud from certain belts from accumulating on the platen as fast too.
It is possible to get a platen hot enough to sizzle water. In that case a cooled platen is a good thing. But it wouldn't be a cure all. A wet belt is going to keep a blade much cooler than a cold platen, but a wet belt isn't compatible with many belts and makes a big mess.
