Renaissance Wax. Every museum in the country uses it on valuable items.
I've heard of this before, but where do you get it? I've seen it online, but not in any stores near me.
Rick,
I'm not "missing the point"
RICK,
What are the benefits of waxing coated blades? Does it slow the wear of the coating or make it easier to clean?
GSM mentioned it smooths out the action on kydex sheaths. Can this cause buildup in the sheath, or is the coating too thin for that to be an issue?
There's also sanding.I've read where members strip the coating on BK knives to "reduce drag" but since I would rather leave the protective coating on, this may be a better alternative.
Yeah, you pretty much covered everything. Thanks for the thorough answer.
I'll have to keep this in mind. I grew up using gun oil and WD-40 on my knives so wax is a new one for me.
Thanks again for the information and pics.
Thanks for the link. I've ever only found it online as well.
I'm not so fortunate, but thanks for the tip.Woodcraft advertises it. If you have a Woodcraft store in your area I'd give them a call.
I'll check it out. Thanks for the information!I didn't bother to look anyplace but Amazon. If you find it in a brick and mortar store I can almost guarantee it will be more expensive
Oh, and here's an interesting bit of info on the benefits:
http://www.restorationproduct.com/renwaxinfo.html
And this youtube clip really points out benefits and other uses for the wax. If its good enough for the British Museum...its good enough for me. ;')
https://www.youtube.com/watch?v=_OZagOg2Bek
The benefit is lubrication. The wax eliminates a lot of friction during all types of use. I, personally like the look of textured coatings a lot, and this is a great way to lose friction while keeping looks. First time I did this I was amazed by how fast my blade carved with minimal effort. It will slow the wearing to a degree due to it being a thin coating of wax that itself will wear off depending on use intensity. It will repel any wet debris, and trap dry debris which will be easily cleaned away.
There shouldn't be any build up in kydex sheaths. That's all I have, and haven't had any build up yet. Just wipe your blade before sheathing as usual. I've always had a debris buildup problem when using oil protectants. I can see a wax buildup on leather sheaths if heavy coats are applied. They are tighter, and have a lot of friction to pull off the wax. After sheathing and unsheathing a lot I would think the knife would slide a lot easier in and out. Also, the interior of the sheath would be sealed off from moisture for the most part. I don't have any leather sheaths, so I can't speak from experience on that.
Hope this sufficiently answers your questions, which were good ones, btw.
