WD-40, why not to use it
WD40 for cleaning & displaycing water / moisture ..
Motor oil for lube ...
Got crudd N stuff on your blade ? Wont come off ? = WD40 ..
I often use WD-40 like a degreaser.
If I'm going to try to free up a siezed lock then I'll use something like tri-flow or some other teflon based spray lube. I find that it works pretty well for that.
I don't use WD-40 to clean out folders because it's not a food safe oil. Usually soap and hot water works pretty well anyways, so long as you dry it out and add oil quickly afterwards.
I always have a can of WD-40 in my rig. Nothing dries wet electrical components like it, it is a good idea to spray plugs and wires ect before washing the engine compartment too.
Works like a champ for drying off firearms after a wet day of hunting, despite all the evils said about why it shouldn't be used. I suspect those that bad mouth it must be soaking stuff in it.
