- Aug 2, 2010
You may have better results using a 110v mig welder if you use .023 wire. The thin electrode will make the machine act as if it has higher amperage to play with, and you will be able to dwell at the toes more easily and put more heat into the weld.
Also, you can try switching your polarity to DCEN (electrode negative), and positive ground. This will put way more heat into the work, which is where 110v mig welders fail. It will burn the electrode more slowly (slower wire feed rate), I run mine like this and it gets great results, a little slower but good hot penetration.
Or you can get a Miller and it will just work perfectly with no hassle.IGBT is the way to go!
Mecha, thanks for that info man. I bought my welder with no previous welding experience, so I searched online about it, read a little bit of info and watched some YT vids and then basically went to "plug and play"
So is it fairly easy to switch the polarity around etc. like you mentioned? I really don't know that much about welders (obviously) so I'm not quite sure how to go about doin that with mine. Also, do you use a 90 amp HF welder as well? I ask because I'm not sure if you were only suggesting that zaph could make that "mod" since he has the 110 amp version, or if you actually read my question as well..
Do you think the changes you mentioned (using the 90 amp HF welder) would allow me to weld a 1/2" thick piece of rebar (with a tapered end) onto the end of a length of, say 1/4" bar stock, thus enabling me to easily forge blades like that without the need of a few pairs of nice tongs?
Anybody have any suggestions for my question in post #13?
Also.. Zaph, please let me know if my questions are out of place and distracting here and you'd rather me make a different thread, or if you don't mind me asking them in here :foot:
~Paul
My YT Channel Lsubslimed
