afishhunter
Basic Member
- Oct 21, 2014
Neither one. The 66 is an 8¾" knife with a 4½" blade, while the 36 is 9¾" knife with a 5½" blade. The Western catalogs called the 36 the Heavy Duty Model.Did the L36 become the L66, or was the L36 the Sears model designation of the L66?
Easy to remember because it makes so much sense.Neither one. The 66 is an 8¾" knife with a 4½" blade, while the 36 is 9¾" knife with a 5½" blade. The Western catalogs called the 36 the Heavy Duty Model.
Western moved to Longmont in 1978, so a Boulder stamped knife probably predates that.
A note about dating knives: Unless the knife has a date code of some kind on it, dating any knife based on tang stamps is an approximation at best. Every chart I've ever seen has had problems, and the charts floating around for Western knives are no exception. The book The Knife Makers Who Went West, written by Harvey Platts himself has a chart in it that's widely reproduced, has many problems. A very common Western sheath knife tang stamp is simply two lines: Western / Boulder Colo. (no 'USA'). The chart says that it should be '31 at the latest, I know from having bought two of them new in the 70s that that is probably not right.
This is not in any way a criticism, it's an observation based on handling a lot of knives. I'm a long time Western collector, and they sometimes stump me. I'm sure I'm not alone. Add to that the idea that anything made before 1990 or so it thought by many to be ancient... There's a lot of history between the end of WWII and the 90s that seems to run together for a lot of people.
Often the best way to date a knife is to post a few close, clear pictures showing the tang stamp, handle construction, etc. Make note of the materials the knife is made of. If you've got the sheath, and think it's original to the knife, that can very often be a valuable clue.
WESTERN over BOULDER, COLO. all by itself on the mark side ricasso, and nothing on the pile side ricasso or on the guard is going to be 1928 to 1936, regardless of what the chart says about 1931 being the end date...
Or Puma ... Otter Messer ... Ulster ... Colonial ... Camillus ... Utica ... and/or even Rough Rider/RyderYou think Western is bad, you should try to date Boker...
Thank you so much for the information! I just started collecting knives a few years ago and there’s so much I don’t know. Because of that I’m so careful in what I buy.Western moved to Longmont in 1978, so a Boulder stamped knife probably predates that.
Thanks!This should work. You could also start a thread entitled something like "How old is this Western knife".
There's a tang stamp chart around here, that might come up in a search.
Not all Western / Boulder Colo. knives without model numbers, be they on the tang or the guard date from the thirties. As I posted earlier, I have two that are stamped as such, and they have to date from the 70s, not the 30s, as that was when they were purchased, they weren't forty years old then. I've seen others. It's generally easy to tell the difference between a ninety year old knife and a forty year old knife.
Knife makers are notorious for finding parts or stamps in forgotten corners and just using them. Add to that the fact that most, if not all knife brands farmed a lot of their product out to other manufacturers and at various times. You've also got to remember that dating knives is a modern affectation that comes from hobby collectors, not from most manufacturers. You cannot say, with any certainty, that the lack of a model number on a guard means manufacture before 1936 (or 1931) when examples from the 70s certainly do exist. Was there a gap between 1936 and 1976 when these knives weren't made? Maybe, it's impossible to know.
In the end it really doesn't matter much. Westerns from the first half of the 20th century aren't valuable knives, at least in part since it's rare to find them in mint condition. They were bought to use, and they were often well used. They are great knives, and their history is usually more compelling than their monetary value.
The bottom line is this: You can't trust any tang stamp chart one hundred percent unless the manufacturer included a date code. You think Western is bad, you should try to date Boker...
Here are some photos you suggested I post. I was recently told this knife was made in the early 60’s. Does that sound correct?https://imgur.com/user/davestwinWestern moved to Longmont in 1978, so a Boulder stamped knife probably predates that.
Sorry, I’m still learning how to post photos. The four photos are in the Western Knife section.Here are some photos you suggested I post. I was recently told this knife was made in the early 60’s. Does that sound correct?https://imgur.com/user/davestwin
I get the home page when I click the link. Not your album.Here are some photos you suggested I post. I was recently told this knife was made in the early 60’s. Does that sound correct?https://imgur.com/user/davestwin
Sorry … I’ll try again!I get the home page when I click the link. Not your album.
