I don't know where you're going out to eat but my burgers are always like the ones on the commercialsI suppose it comes down to advertising, if companies use the knives they send out in the advertisement people would probably not buy them. I think most people believe they will get the one that is advertised , when is the last time anyone got a hamburger that looks like the one on TV
Collectors pieces are show ponies, you don't ride them, you show them off, so they need to be beautiful, I agreeDepends on the knife, where I bought it, and how much I paid. I’ve only sent one back that I can remember, for a big discoloration spot on a $200 limited edition knife. I’m mostly a collector, but I have a solid rotation of ZTs and some other brands that I use. If it’s gonna be a user I will put up with a lot more than if it’s going to be a safe queen.
The most important thing to me is the grind. Just about all production knives have good lockup, action etc, but some brands are very inconsistent with the final bevel. Ironically enough, it is the safe queens, - that I’ll probably never use - are the ones I want to be the most perfect.
Yes indeed.I'm okay with minor cosmetic imperfections on lower cost mass-produced factory knives of a hundred or two hundred dollars. For example, if a blade coating isn't completely spot on, the centering is a tiny bit off, the grind isn't completely even, and so forth. On less expensive knives, I'm also okay if the pivot is a bit finicky. If we're talking about a knife that costs say four or five hundred dollars or more, I expect a much greater level of detail to the finish.
So I don't expect my Spyderco or Benchmade knives to have the fit and finish of a Chris Reeve Sebenza, and cosmetic imperfections that are acceptable for the former would be completely unacceptable with the latter. At the same time, I don't expect the cosmetic finish of a Seb to compare to a high-end custom knife.
Also, when I am at Sebenza pricing for a folder, I do kind of expect a design that allows the knife to be taken apart and reassembled many times and still operate correctly without any changes in performance whatsoever (e.g., the development of blade play or lock issues) and this is partly how I can justify something more expensive.
A knife will continue to cut until it breaks in two, then maybe pick up the bigger of the two pieces and shove it some wood and get to workingOften, when someone has taken apart some Spyderco and is like "Well, I have noticed this scratch in the side of the lock face, is this typical of Spyderco" bla bla, Sal replies with "How's it cut though?".
Truly a man of minimalism! HahaA knife will continue to cut until it breaks in two, then maybe pick up the bigger of the two pieces and shove it some wood and get to working![]()
