- May 21, 2000
Liner/Frame Lock.
Simple and effective.
I'm curious why so many people think frame locks are so strong? There are stories of them failing and videos showing they catastrophically fail with a lot less force than other locks. Twist or cut 'out' with a knife like when whittling can cause the lock to walk across the blade tang and close which is a failure without damage. I have had multiple failures like this with both liner and frame locks. And they weren't cheap knives but ones from companies that are praised here many times a day. Even if this didn't happen, frame locks just aren't as strong as other lock types like so many people think.
My favorite lock is the AXIS, followed by compression, then caged ball bearing. This type of lock is a lot stronger where a small piece of metal is wedged between blade and the fixed stop pin. The difference between these and liner/frame lock is similar to jacking up a car and holding up a car wheel with a 2x4 laying on its side, and holding up a tire by sitting it on top of a fence post. Plus you don't have to put your fingers in the blade path when closing and they are fairly ambidextrous. Plus from an engineering perspective, no lock is quite as elegant as the AXIS lock IMO.
To each their own, but I have used them all and know which I have had serious problems with and which I haven't.
Yeah the axial lock is quite interesting for sure. Here is some more info on it for those who are interested.Look up the Gerber 'axial' lock. Invented by Paul W. Poehlmann and is elegantly simple and quite strong. I have a Gerber 'Paul Knife" and think it's great.
The Hawk Lock is my favorite. Simple to use and keeps my fingers out of the path of the blade at all times.
My two favorites are -
# 1 the Axis lock - very strong. super smooth operation. Easy one hand open and close.
# 2 the Tri-Ad lock - arguably the strongest of all but no one handed operation.
No lock type is immune to sub-par production resulting in a failure prone mechanism just waiting to amputate fingers of the careless user.
