- Feb 24, 2000
I thought I would start a thread where knifemakers could share things they have learned that has made a particular aspect of knifemaking easier.
I sold my first knife in 1980, and have learned a lot of ways to do things easier and to save time.
One thing I have learned that makes it easier and saves time has to do with hand sanding a satin finish. I do both forging and stock removal. I started using ATS-34 for stock removal. I would grind the blade to 400 grit send it off to Paul Bos heat treating and then when It came back I would start hand sanding. I would start with 220 grit, go to 320 grit, etc. and stop with 1200 grit. It took forever with the 220 grit to get all the 400 grit scratches off the blade.
So, I got smarter and started hand sanding BEFORE the blade was heat treated. I would start with 220 grit and hand sand up to 400 grit and then send the blades off to be heat treated. Sending blades to Paul Bos heat treating I can grind the edges really thin and they come back in perfect shape, no warping. Sanding before heat treatment made it a lot easier.
Then I decided to try to use a Norax 22 belt after the 400 grit belt. It's amazing. Now after the Norax 22 belt I skip the 220 and 320 grit and start hand sanding with 400 grit and in a very short time less than five minutes I have all the grinder scratches out of the blade and it's ready for heat treatment. I now use CPM 154 steel but it sands and works the same as the ATS-34.
That's one thing I have learned that makes a satin finish much much easier and saves a lot of time.
