The chape cannot be left off, due to the scabbard construction. The wooden halves are "shrink wrapped" in not-quite-cured leather, back-stitched while the leather is wet, and left to dry. This leaves the scabbard tip open (possibly with the wood exposed on some) and must be covered. A leather piece, shaped like a fan with four broad blades, could be pressed into a mold while wet to give it a primary shape, and then wet-molded to the scabbard tip when ready, glued, and left to dry. This is nearly as "labor intensive" as making and fitting the brass chape, and will require sarki skills and leather knowledge, therefore it shouldn't cause them to balk at the change as a cost saving measure. Some cost savings may come with the difference in use of leather vs. brass, but not if the grade of leather necessary is costly or difficult to obtain. Tooling is another thing. The grade of leather on the villager I received is far and above that on my other scabbards. Uncle says it is hard to tool, but the trade-off, IMO, is worth it. I have also wondered if what we perceive as "traditional" scabbard styles may not be more along the line of "business as usual" - ie: give them what they are used to seeing. I'm stymied by the picture of all these blade styles, from widely varying tribes, cultures and regions, all winding up in one scabbard design. The metal chape is all you see on everything from villagers to kothimodas, but there must be other styles out there. What we need is a "Sanu-Sarki" who can push the envelope just a little bit
One of the problems of making changes is in making a change that they are able to do. We tend to take for granted things that can only be done with a stamp press, while they are still stuck with home-made hand tools for the brass portion of their metal forming. While they may or may not balk at a change from what they are used to doing, the difference in pay rates between kamis and sarkis is a rub (it is a rub between machinists and tool & die makers in our shops, or any stepped-rate shop). If a change puts more work on the sarkis for the same pay, we have lost rather than gained. If there is time saved on their part, and they can make one or two more scabbards a day, everybody gains.
